Results 1 to 3 of 3
Thread: another clutch problem
09-28-2010, 06:43 AM #1
hi all
after my dad frind fix the rear engine seal by remove the tranny.when i press the clutch pedal it stuck at the floor(not like the old storie) if i press the half it go down and i cant shift to any gear,the master & salve cylinders changed before 10 months i asked him if he did the bleeding he said yes, but i dont think he did it.nothing happend when press the pedal it wont shift and stuck down even if i rise it up by my foot it go down slowly some time.does the bleeding fix this problem???please help
09-28-2010, 03:35 PM #2Senior Member
- Apr 2008
- Madison, WI
Yes. It sounds like the clutch needs to be bled. It can be difficult to do using the conventional method. Using the Mity Vac method describe in the sticky link below makes the job a lot easier
How to bleed a clutch with a Mity Vac
09-29-2010, 02:43 AM #3
he did the bleeding today but nothing change he said he is sure the slave cylinder is leaking.he told me about brand called Luke!!or somthing like that first time heard about it.
the master is from Ram racing clutch & the slave GM performance ,so i think the gm salve didnt last too long 10 month only.
Clutch problem
By 77k5 in forum DrivetrainReplies: 1Last Post: 05-02-2009, 09:09 PM -
LS7 clutch problem.....
By nmssr08 in forum Manual TransmissionReplies: 14Last Post: 12-16-2008, 04:57 AM -
Clutch Problem
By Blackout01 in forum Manual TransmissionReplies: 2Last Post: 08-07-2007, 02:48 PM -
is it a clutch problem, or a tranny problem?
By sgt0704 in forum Manual TransmissionReplies: 3Last Post: 01-07-2007, 04:03 PM -
Clutch problem..help please
By Scorch in forum Manual TransmissionReplies: 16Last Post: 03-02-2006, 09:34 AM
