Thread: Timing chain help.
08-05-2007, 04:54 AM #1Junior Member
- Memphis
Sunset orange- 2002 Camaro Z28
Timing chain help.
OK here is the deal. I changed my cam out about a year ago. I also changed out my timing chain to a LS2 chain. I am now upgrading my cam, heads, intake, maf and throttle body to the 90/90 set up. The question I have is what timing set should I go with this time. I want to change out the gears and chain this time.Should I go with stock gears and get a LS2 timing chain again or is there something better I need to go with. Give me your help if you can. Links to product that you recommend would be great.
Thanks
08-05-2007, 07:35 AM #2
08-05-2007, 11:46 AM #3
you should be just fine getting another ls2 chain if you just feel that the one you have has already started to stretch on you. You really shouldnt need new sprockets unless you go with a double roller setup or want an adjustable setup. There are definatly some better than the LS2 but it involves more work and money. check the other timing chain thread..
08-06-2007, 04:48 PM #4Member
- Oct 2005
- RI
Mag Red- 2002 Vette
Another option is the Katech (JWIS) chain, which is a single chain that will fit the stock sprockets. It's the one the C5R ran and Katech stated they never had a timing chain break in any racing with it. It is more money though.
timing chain
By RedHot99T/A in forum External EngineReplies: 7Last Post: 01-31-2011, 02:58 AM -
For Sale: Timing Chain Set
By Dillard99 in forum Parts For Sale / TradeReplies: 0Last Post: 06-25-2008, 09:35 AM -
LS2 Timing chain set
By sammy burks in forum Parts For Sale / TradeReplies: 6Last Post: 03-24-2008, 11:02 AM -
Ls1 timing cover, Dual row timing chain
By xssive in forum Parts For Sale / TradeReplies: 0Last Post: 08-06-2007, 06:41 PM -
timing Chain
By 2001bird in forum Internal EngineReplies: 7Last Post: 11-14-2006, 05:15 PM
