Thread: supporting mods
    harrisburg pa
    maroon
    2002 trans am
    supporting mods
    im thinking about getting heads and a cam, the afr 205s and maybe the vhp accelerator, and a 125 shot. what supporting mods do i need to do it right? thanks for any help
    houston
    2001 z28
    lts, tune, and some bigger injectors.
    Senior Member Wheeler99WS6's Avatar
    indiana
    black, 05 Roush
    black, 99 T/A WS.6
    List what mods you currently have so we can better help you. Heads and cam you will need free flowing exhaust. You already have an LS6 intake so you should be good there. you will also need to make sure you springs in your new heads are compatible with the specs of your new cam. I am unfamiliar with that cam. also if you are an auto you might want to pick a TC and tranny cooler.
    1999 T/A WS6 Black -------SOLD
    05 mustang Roush sport;
    DOB manifold, m122 SC, 47lb injectors, gt500 TB, roush TVS CAI, Detroit rocker SC grind camshafts, Mac LTs, off road x, roush off road mufflers, roush short throw shifter, kenne bell BAP, Brenspeed 93 octane tune. 479rwhp 436ftlbs SAE.
    harrisburg pa
    maroon
    2002 trans am
    what size injectors? also i was thinking maybe id need a maf?
    I would also look at a racetronix fuel pump kit. Ported/polished tb wouldn't be a bad idea either. While you're at it I would start shopping for a 12 bolt rear.
    harrisburg pa
    maroon
    2002 trans am
    ah good point i havent even thought about the rear yet.. how much do our diffs generally hold? im bone stock so far.. low mileage m6. im still undecided about the cam i think i might go with the torquer v2. how beneficial is it to actually buy performance heads as opposed to building stock heads?
    NC
    1998Z28
    You can pickup 50 RWHP with a set of Stage 1 LS6 Heads if you have the modds to pull it off with. 4.10s work better with 6 speeds. 3.73s work better with Automatics. LEAVE the MAF alone!! Just put down that screwdriver and forget about it.
    TSP 347 SB, TSP Stage 2.5 PRC LS6, TSP MS4, Performabuilt Stage 2 4L60E, Yank PT4000, 4.11s, Fast 90/90, FTRA Cold air intake+all the free mods, Dynatech Supermaxx Exaust System, DMH Cutouts, Hooker Catback/FTRA Tips. Tuned by RPM/Garner NC. 11.28@119
    harrisburg pa
    maroon
    2002 trans am
    haha thanks. does anybody have the patriot stage 2 59cc ls6 head/cam kit? it says itll give me 11:1 cr. ive read that higher compression is useful in nitrous applications.. i know a bunch of you guys are daily driving with over 500 whp but ive also read that the connecting rod cap bolts are rated for around 500 hp. is that something i should worry about? im just trying to do all of my homework before i start ordering parts
  1. Best supporting mods for cam
    By dethinboots in forum Internal Engine
    Last Post: 10-03-2014, 09:17 PM
  2. Question: heads and cam supporting mods?
    By Professor Chaos in forum Internal Engine
    Last Post: 02-18-2009, 01:49 PM
  3. Question: Big Cam, What supporting Mods do i need?
    By 1998 T/A in forum Internal Engine
    Last Post: 12-17-2008, 06:31 PM
  4. clutch and gears - supporting mods '98
    By SpecterGT260 in forum Drivetrain
    Last Post: 08-15-2008, 04:44 AM
  5. FS: '99 TA, new 402 ls2 motor and supporting mods.
    By djvaly in forum Cowhands, Local Parts and Fish Bait
    Last Post: 11-17-2007, 10:30 AM
