Results 1 to 14 of 14
    Insurgent Hunter dethinboots's Avatar
    May 2011
    Fort Hood
    Impulse Blue
    2005 a4 GTO
    Best supporting mods for cam
    In the market for some more add ons. Would like to know where I would get most bang for buck. Doesn't have to just be things that increase horsepower either.
    2005 Impulse Blue GTO
    Kooks Longtube Headers (off-road mids) , SLP Loudmouth II Catback, Vararam OTRCAI, MSD Spark Wires, 238/242 .595, Trickflow 225cc Heads, SLP 25% UD Pulley, Breather, Elite Engineering Catch Can, 3200 TC,Hayden Trans Cooler, P&P TB, Dyno tune by Sunshine Performance
    budget and the mods in your signature the current mods?
    May 2011
    Fort Hood
    Impulse Blue
    2005 a4 GTO
    budget is 2500ish and yes those are current mods
    Not sure about suspension for the Goat but that $2500 will get you
    FAST 102, NW 102 TB, LS2 fuel rails and new injectors and might leave enough room for a tune.
    You already have a cam so another option would be heads. You can get a great set match to your cam from AI.
    May 2011
    Fort Hood
    Impulse Blue
    2005 a4 GTO
    Heads are within that range? And would they be a good option before fast?
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Best option would be to save longer and get and install both at the same time; heads and intake...if that's the route you want to go.
    Jons right in it will be cheaper in the cost because of tuning* but you could go either way.
    If you have a LS6 intake I'd do the heads first because of the labor it takes to do heads vs an intake swap. Heads can take all day vs 1-2 hrs for intake.
    Plus with heads you'll get more for the money vs a FAST intake at first.
    If you do go with heads, remember it's also gaskets, fluid change, new head bolts (go ARP) and time to do it. Using the MWR shop on base will help a lot.
    * - If you do them separate you need to tune twice where as at same time it's all in one session.
    May 2011
    Fort Hood
    Impulse Blue
    2005 a4 GTO
    Saving woukd be the best route, but new heads are rather pricy. Good things come to those who wait I guess lol. And @ SMWS6TA no mwr in Lithuania lol
    Thought you were still at Hood. Wait till you get back.
    May 2011
    Fort Hood
    Impulse Blue
    2005 a4 GTO
    Just shipped out about a week ago. Im really tire of Europe and hope we are home longer than a couple months after this.
    Stay safe, bud.
    Ditto^^^
    Funny my wife was in Germany for 3 yrs while I played in all the Baltics during Clinton. I missed every damn Octoberfest. That is a crime.....
    Arizona
    This has been mentioned to you from several other people before but it bears mentioning again. You really need a converter in that thing, that's a very easy 1/2 second in ET right off the bat for very little money and no loss of drivability. Much easier than a cylinder head change too. That converter should have went in back when you did the camshaft swap anyway. Trust me once the converter is in you'll wonder why you didn't do it sooner.
    I'm also thinking this should be in the GTO section?
    May 2011
    Fort Hood
    Impulse Blue
    2005 a4 GTO
    the converter has been on my mind for quite awhile, but still haven't been completely sure what it will all entail. ill do the research since ill have the time, but it seems way over-do just like the suspension mods I should do. And I apologize ill put it in the correct section next time.
  1. Question: heads and cam supporting mods?
    By Professor Chaos in forum Internal Engine
    Last Post: 02-18-2009, 01:49 PM
  2. Question: Big Cam, What supporting Mods do i need?
    By 1998 T/A in forum Internal Engine
    Last Post: 12-17-2008, 06:31 PM
  3. clutch and gears - supporting mods '98
    By SpecterGT260 in forum Drivetrain
    Last Post: 08-15-2008, 04:44 AM
  4. FS: '99 TA, new 402 ls2 motor and supporting mods.
    By djvaly in forum Cowhands, Local Parts and Fish Bait
    Last Post: 11-17-2007, 10:30 AM
  5. supporting mods
    By llcooljosh in forum Internal Engine
    Last Post: 08-08-2007, 03:46 PM
