Results 1 to 16 of 16
    United States Marine Kamauxx's Avatar
    Kansas City, MO
    Blazen Orange Metallic
    2006 GTO
    Stall converter and overheating?
    Hello forum. I'm a rather noob when it comes to performance upgrades.
    Friday I'm purchasing a Z28 with 17K miles and some mods. One of the mods is a 2800 stall converter ( or something like that ). I read somewhere that there is a chance of that mod causing heating problems. What should be done to the car to prevent this?
    Car Nut ICRAZY6's Avatar
    Feb 2006
    Lacon, Illinois
    2002 Trans Am WS6
    Just put a transmission cooler on and that would be all that's needed. Check the f/s section for one or summit sells them for about $45-50
    Senior Member
    Jacksonville, FL
    Might even already have one - most people who put in stalls do an aftermarket cooler at the same time.
    Kansas City, MO
    2006 GTO
    That's good to go. I'll have to ask him tonight. Thanks everyone.
    *edit* Is the aftermarket cooler something that I can see by peeking under the vehicle or is it hidden? And if I have to install one, how hard is it to do?
    Castle Rock, CO
    Montego Blue
    '07 BMW 328Xi Coupe
    Try looking in front of the AC condensor to see if its already on there. If he knows what the hell hes talking about in terms of mods, chances are that the car has one already.
    Feb 2006
    Lacon, Illinois
    2002 Trans Am WS6
    looks just like the condensor its self except smaller. Mine is 10"x6" I think.
    Kansas City, MO
    2006 GTO
    He told me the 2800 he had installed doesn't require a cooler. Does this sound wrong?
    NY
    yellow
    02 Collector Edition TA
    Yank recommends anything 3000 above use a cooler. My yank i'm running in my FWD buick makes that fugger run hot, its not uncommon for a higher stall to increase the temps by 30*-40* depending on how large. Example, anything under 3000 (approx) on mine is technically, slipping, producing heat.
    Castle Rock, CO
    Montego Blue
    '07 BMW 328Xi Coupe
    Yea, do yourself a favor and get one anyway. You don't want to take the chance of screwing up your tranny because of increased friction.
    '05 BMW 330Ci ///M Sport 6Spd
    '99 WS13 Trans Am A4 - Gone but not forgotten
    '01 Firebird Convertible A4 - History
    Indianapolis, IN
    All Black
    83, 87, 02 All WS6 T/As
    I agree.. get a cooler anyway, blowing your tranny cause of that is stupid and expensive....
    -Geno
    1983 Black WS6 "WindCharger"
    1987 Black WS6 "WS87"
    Sold the other four f-bodies
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    It is not the stall speed as much as the diameter of the TC, the smaller the converter the hotter the transmission will run.
    SteveC
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    even if you dont have a aftermarket stall, heat is the main killer of automatic transmissions.
    a cooler is totally needed for any size aftermarket stall
    a few bolt ons, 379 rwhp
    11.96 @113.25
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    If your vehicle is stock height (not lowered) the B&M 3 Qt. deeper aluminum pan will also help to keep the temperature down.
    SteveC
    Kansas City, MO
    2006 GTO
    I'll check on a cooler Monday. Thanks for all the help gents.
    The car is stoopid fast by the way!!!
    Castle Rock, CO
    Montego Blue
    '07 BMW 328Xi Coupe
    Yea mines stupid slow.
    Quote Originally Posted by Kamauxx View Post
    Yes, this is wrong, buy a cooler or your tranny will go adios real fast. Heat kills automatic trannies faster than anything.
    Painted manta stripe
  1. Stall Converter
    By Autoslick in forum Automatic Transmission
    Last Post: 10-04-2009, 11:03 PM
  2. Replies: 15
    Last Post: 07-02-2007, 02:49 PM
  3. need stall converter
    By dicks99ta in forum Parts Wanted / Trade
    Last Post: 04-14-2007, 10:05 PM
  4. stall converter
    By bigmike98ss in forum Automatic Transmission
    Last Post: 12-22-2006, 12:08 AM
  5. stall converter
    By Z28Y2K in forum Automatic Transmission
    Last Post: 08-03-2006, 08:02 PM
