Results 1 to 11 of 11
    Michigan
    2002 WS6 Trans Am
    What can you do to get your hatch to stop rattling?
    I have one JL Audio sub in the back and i want my hatch to stop rattling, what can i do? Thanks for your help.
    Marc
    Senior Member MadSeason's Avatar
    Indiana
    Dynamat
    Colorado
    99 Z28
    Do you know where SPECIFICALLY it is rattling at?
    Michigan
    2002 WS6 Trans Am
    No, i can just hear it when i'm outside the car
    Drexel Hill, Pa
    Maybe you can raise the little rubber bumpers like the ones to adjust your hood height.
    Colorado
    99 Z28
    Start touching different places to see where the rattle is coming from. Is it the license plate? Is it the spoiler? Is it INSIDE the spoiler? Is it a tail light? Is it a tail light wire bouncing against the back of the car? Is it the plastic trim on the bottom (inside) of the hatch? With out knowing where it's rattling, I'd have absolutely no idea where to begin to tell you to make it stop.
    Oh yeah, dynamat... expensive and not worth it IMO
    Member Duffster's Avatar
    Hamilton, Illinois
    2001 Camaro Z28
    What Dr Milhouse almost said! ! !
    If you find the spot, also if you remove the trim underneath the hatch where it's rattleing, you can tighten down on the nuts holding the wing in place (if thats it) or adjust those plastic bumpers to 'snug-up' the hatch when it's shut! Dynamat will stop the noise if it's simply the metal part of the hatch vibrating due to it's size (the part of the hatch that bolts onto the glass - about 10 inches wide and 4+foot long - painted body color). . .
    hope this might help some. . .
    Duff
    http://i10.photobucket.com/albums/a1...r-01Z/sig2.jpg
    Currently own 1995 Z28 (Silver-Automatic) - BONE STOCK!!!
    Recently purchased 2001 Z28 (Black-6 Speed) - 3" Flowmasters and
    other misc stuff. This, bad traction (2.21 60') and missed 3-4 shift
    netted me 13.46 sec in the 1/4 mile. . .
    b52bomber
    Guest
    I am having the same problem when I hits small bumps on the road. It sounds like the metal part of the wire and I have adjusted the rubber bumpers. If you find the problem, let me know.
    Hamilton, Illinois
    2001 Camaro Z28
    Oddly enough, I noticed a little rattle a few days ago myself. I checked by adjusting my stereo pretty high and stood outside. . . It was the little panel between my tail lights. . .adjusted tighter and all is good in the world now...
    Just a possibility. . .
    Duff
    b52bomber
    Guest
    Duff,
    Thanks for the tip. I will give it a try as the rattle is driving me nuts.
    TrentB52
    Hamilton, Illinois
    2001 Camaro Z28
    And the old man in me says:
    "Turn that racket down! ! !"
  1. back hatch rattling when go over bumps
    By ASh302 in forum Firebird / WS6
    Last Post: 04-11-2015, 06:46 PM
  2. Help: '01 Ram Air TA Rear Hatch Lift Strut Mount loose in Hatch
    By NAVYGSE1 in forum General Help
    Last Post: 12-20-2011, 01:07 PM
  3. Rattling cat?
    By Spikito in forum External Engine
    Last Post: 05-26-2011, 06:41 PM
  4. Rattling when coming to a stop
    By Gohard in forum General Help
    Last Post: 08-21-2010, 03:19 PM
  5. New Slp LM II rattling!!!
    By matt123 in forum General Help
    Last Post: 02-22-2007, 09:19 AM
