Results 1 to 1 of 1
Thread: some major cooling issue
07-27-2007, 08:36 PM #1
alright guys i got some big time weirdness goin on with my car...'94 firebird formula back in december when i bought her she ran a constant temp of 180, then a few months later it would when idling it would make its way up to 210 i changed the thermostat, nothing, i replaced the radiator and things got worse from there. now since the radiator has been changed the temperature goes all over the pace, 180-210 its in constant flux, usually if i had the ac on (which makes the fan run) it would keep the temp under control at 180, but now even with the ac on the temp guage is all over the place and at times it reads low coolant even when the coolant level is completely full. anyone have some order to this chaos? much ablidged
pvc issue... vacuum leak....tune issue?
By okiels1 in forum General HelpReplies: 3Last Post: 03-05-2016, 09:10 AM -
major issue not starting - crank relearn ? expert needed
By devic in forum External EngineReplies: 14Last Post: 07-31-2012, 03:17 AM -
Help: Cooling/Overheating issue
By Matto4785 in forum General HelpReplies: 5Last Post: 05-15-2012, 03:23 AM -
cooling issue
By JAX04 in forum GTOReplies: 28Last Post: 04-15-2011, 01:18 PM -
cooling issue
By wolverine442 in forum Internal EngineReplies: 10Last Post: 06-16-2009, 01:15 AM
