Results 1 to 11 of 11
Thread: cooling issue
    Jun 2009
    north carolina
    2001 ss camaro
    cooling issue
    I have a stock 2001 ss camaro and the temp. gauge will rise to around 210 and just stay there, no matter if I'm cruising or idleing . Should I be concerned about this being to hotor do most ls motors run this way.
    Thanks
    Member c5z28's Avatar
    Bay Area
    On your ass flashing
    my highbeams
    Our cars run hot so the cats work efficiently, your car is perfectly normal as long as the temps don't fluctuate.
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Your fine
    Thats just a dummy gauge anyway.
    I run a backup digital gauge that shows my temp running between 185 and 192 with a 180 thermostat. My stock gauge reads a bit under 210 all the time once the engine is warmed up.
    When changing my thermostat, it was still airlocked at initial start up and the temp came up to 225 on the digital gauge. Even there, the stock gauge stayed put at just under 210.
    The stock gauge is an approximation at best...
    St. Clair Shores. Michigan
    `98 Formula M6 HdTp
    Your fine
    Correct 1998 is the only year LS car with a properly functioning Temp guage.
    Craig
    Semi Retired Street Racer
    Gone but not forgoten
    NBM `98 Formula M6 HdTp
    1 of 1 Build Date 3/12/98
    🤔 11s. blackbirdbrain89's Avatar
    hagerstown, mercersburg
    black trans am
    2000
    that might be the only better thing for a 98 then any other year lol.... but mine seems to be right from hp tuners logs and stocker
    Florida
    1999 TA WS.6
    Shit mines off 20-25 * from what HPT reads. I dont give any mind to that guage as long as its where it usually is.
    Junior Member krazykarl454's Avatar
    quakertown PA
    yea on my 98' it will move around abit. when its movin its around 180ish, and in traffic the low speed fan will kick on around 210 and drop her back to around 180ish. never had the high speed fan kick on. she runs nice
    Member 1998 T/A's Avatar
    Aug 2008
    Huron Ohio
    2000 WS6 Trans AM
    mine gets to 210 in stand still traffic but once im cruising its at a steady 160-170
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    Just check the intake to the radiator under the car and make sure there is no trash. Every no and then I will pick up a plastic bag that has to be pulled out of there. I notice it in the A/C the most but the temp will only move a hair on the stock temp. other than than that it's normal
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Quote Originally Posted by 1998 T/A View Post
    Yep. Same here.
  1. idle issue.. may be tune issue.. help?
    By okiels1 in forum General Help
    Last Post: 12-07-2016, 02:17 PM
  2. pvc issue... vacuum leak....tune issue?
    Last Post: 03-05-2016, 09:10 AM
  3. Help: Cooling/Overheating issue
    By Matto4785 in forum General Help
    Last Post: 05-15-2012, 03:23 AM
  4. cooling issue
    By JAX04 in forum GTO
    Last Post: 04-15-2011, 01:18 PM
  5. some major cooling issue
    By abarthle in forum Firebird / WS6
    Last Post: 07-27-2007, 08:36 PM
