Results 1 to 11 of 11
    Senior Member clg82's Avatar
    Feb 2007
    California
    2000 Trans Am
    3.73 gears worth it???
    I already have the 3.42 performance axle in my car. It's an automatic and is my daily driver, and i do take it to the track sometimes. Would it be worth it for me to go with 3.73 gears and will i notice a difference? If so where will I feel the most difference? Thanks for the help.
    TN
    2005 GTO M6 Black
    2000 Z28 A4 Red
    Just go ahead with 4.10's and be done
    My Toy 00 Z28 1SC A4 - MS3 cam with supporting valvetrain, Milled LS6 heads, LS7 lifters, , ARP rod and mains, All free mods, pacesetters, True duals, moser 9 with 4.11's and Detroit Locker, Vig 3600 tuned, tubular SFC,adj PHR, LCA, adj TA, PHR reloc, LCA reloc. all with poly bushings, ZR1's and Nitto DR's (315).
    My other toy 05 GTO LS2 M6- Comp XR269HR cam, 918's, hardened pushrods, Dart Pro 1's, pacesetters, X-pipe, flowmaster 1 chambers, TSP oil pump, Tick master cylinder. Pedders RR bushings, end links, SB bushings, tie rods and strut mounts, total performance poly F&R bushings. Polk DVC 12", Infinity Kappa 6.5 component and 6x9's with corresponding amps.
    Her toy 77 F100-6.6/c6. All original (for now)
    FAQ2 99DROPTOPZ's Avatar
    Chicago
    1999 Chevy Camaro Convert
    I agree, go with the 4.10 gear if anything I doubt you'll see the difference you want by going with the 3.73. Besides, if you're going through the trouble of doing the work or paying for it, make it worth it. Just remember you're losing top end the higher the gear ratio.
    Feb 2007
    California
    2000 Trans Am
    4.10's in an automatic that is my daily driver are you sure??
    Chicago
    There's a 3.90 gear if you want to go a little smaller
    Impounded MikeSomething's Avatar
    Old Bridge, NJ
    Pewter Metallic
    '00 Z/28
    3.73's is the highest I'd go man...Only because it's an A4 and it's your DD.
    LS1-TA schrysler's Avatar
    utah
    1998 Trans Am Vert
    If Its An Auto Then 3.23s Were The Lowest That It Came With From The Factory
    1998 Trans Am Vert, M6, Soon to be full of goodies......
    d
    2002 z28
    not unless he got one from a 6 speed casue that came stock for them
    Marylandistan
    2001 Trans Am (sold)
    Automatics didn't get the 3:42 axel. Which is it?
    Senior Member Zboner's Avatar
    cincinnati/northern ky
    99 SS
    its not that bad.. honetly i think on the E way at 75 your pulling 2.8-3k rpm's
    d
    2002 z28
    Quote Originally Posted by INMY01TA View Post
    auto come with 2.73, 3.23 M6 came with 3.42
    he could of installed some gears from a M6 or the presiois owner put them on
  1. 4.10 gears worth it?
    By JDCAMARO99 in forum Drivetrain
    Last Post: 05-28-2014, 09:04 PM
  2. Question: What ET gains are 3.73 gears worth???
    By the71ub4cm30 in forum Drivetrain
    Last Post: 10-19-2011, 06:40 PM
  3. Help: about to change my plastic gears for brass gears
    By edrvsqz1980 in forum General Help
    Last Post: 07-18-2009, 05:09 PM
  4. Is headers tune and gears worth the money.
    By Street Fighter in forum External Engine
    Last Post: 02-10-2009, 09:29 AM
  5. 3:73 gears, 3:42 gears, clutch, flywheel, plug wires
    By ls1hater in forum Parts For Sale / Trade
    Last Post: 08-16-2005, 06:15 PM
