Results 1 to 13 of 13
    Calgary, Alberta
    2001 SS Vert
    Good daily driver cam?
    2001 LS1 convertible
    I have had this cam sitting around for a while wondering if it would be suitable for daily driving.
    218 / 222 @.050
    .562 / .566 intake exhaust
    115 center line
    Are my brakes going to suffer? I live at 3400 feet, Calgary, Alberta
    Any input appreciated.
    LWM
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    its a small cam, youll be fine with above for daily driving.
    a few bolt ons, 379 rwhp
    11.96 @113.25
    Senior Member ninobrn99's Avatar
    Aug 2003
    Honolulu HI
    all bore 370 Trans Am
    that cam is cute depending on the overlap, it could be a big sleeper. You'll have great power down low with that cam.
    constant modder councelor hissin'98's Avatar
    Utah
    Black '98 Z/28 M6
    H/C/Turbo....why?
    This is a very mild cam, good for daily use. No your brakes will not be affected. It might have a slight idle but on the wide (115lsa) you wouldn't notice it. It will great performance tho and still retain the gas milage.
    Calgary, Alberta
    2001 SS Vert
    Quote Originally Posted by ninobrn99
    Cute ... shmute, I asked because ...
    LS-1 F-body cams
    98-00: 202/210 .496/.496 116 LSA
    01-02: 198/197 .478/.478 115 LSA.
    LS-6 cam 204/218 .551/.547 117.5LSA
    My cam in question
    218 / 222 @.050
    115 center line
    to me looks like it is significantly bigger than the LS-6 cam, and, in another life, because I put in a 224 / 236, .536 / .555 Intake Exhaust on a 114 LSA in a 383 with 9:1 compression and AFR heads ... result was a significant loss of vacuum which compromised my low speed braking. Might just have been the big heads ... what ever. anyway the comment about power down low was what I was looking for ... thx
    Quote Originally Posted by hissin'98
    That is the kind of cam I'm looking for, a few extra horses but not willing to put up with a lot of downside.
    thx for the replies and I think I'll have it installed.
    LWM
    Junior Member MNR-0's Avatar
    Australia
    BLACK
    2004 Monaro
    I would reduce the intake duration somewhat - something to 212 or 214 and run on tighter lobes. Make power at same point but much more torquey down low with little to sacrifice in terms of peak power. Reason is for the stock power band, you dont need massive inlet durations to make good power at 6000RPM. If you aren't rebuilding your engine to spin past 7000RPM I dont understand the need to go big - unless you're a crazy MOFO that loves cranky idles lives at the redline.
    You only need so much duration to maintain peak pumping efficiences. Too much duration and you lose torque under 5000RPM. If its a daily driver, my recommendation is to keep it small. Remember, torque gets you the 60'. If you have a big cam, you need to take off at 6000RPM or invest in a 4000+ stallie. Too many compromises in a DD if you ask me.
    Calgary, Alberta
    2001 SS Vert
    Quote Originally Posted by MNR-0
    You may be closer to the truth than you think.
    I road course that car, yup, road coursing a stock 01 SS convertible. Needs a little more power, and I can't count how many times I've smacked the 6,200 rpm fuel shut off trying to catch up to an SRT4 Neon .... dang those things sure do scoot ...
    What would be your opinion on my brake/vacuum concerns?
    And FWIW I have a set of Wilwoods on the front and some Strano bars on the way.
    Cheers
    LWM
    Australia
    BLACK
    2004 Monaro
    Quote Originally Posted by LWM
    Cheers
    LWM
    With a cam like that - absolutely none. You will lose some vacuum, perhaps 5kPa at idle - but thats about it. You don't brake from idle anyway.
    Our stock GTS in OZ came out with a 212-220-119LSA cam - 700Nm of torque at 4000RPM - gotta love that.
    Aug 2003
    Honolulu HI
    once again, if there isnt much overlap on your cam, which im guessing there isnt looking at the specs, but i could be wrong. You will not loose much vaccum at all. If you did, it should still be very easy to tune your ve and get it on point.
    RI
    Mag Red
    2002 Vette
    I am running a VHP cam with Crane 1.8 rockers. Cam is 216/224 .583/.583 (with the 1.8's, otherwise .551/.551) with an LSA of 115. Idle is good, vacuum is very good (tuner even commented vacuum was very good) and it makes good power. Peak power is at 5,800 RPM, which I like because I don't want to rev the crap out of the car to make power and I don't drive it on the track.
    Metro Detroit
    Anniv. Red
    2003 Corvette
    Quote Originally Posted by vettenuts
    Hmmm, those numbers are very close to the GM Hot Cam [219/224]. Isn't that something?
    samdogmx
    Guest
    that should ne a good cam for a DD, shouldnt have any effect on your brakes.
    Calgary, Alberta
    2001 SS Vert
    Thx folks
    The surgery is scheduled for Nov 22, 2005.
    Also have some better valve springs, push rods, guide plates and a set of RRs, stock at 1.7. looking for 25 - 30 HP.
    And if the US postal service is with me ... a set of Strano 35 / 22 mm bars.
    LWM
  1. Question: Good idea for performance/daily driver? 02 LS1
    By arock24 in forum Camaro / SS
    Last Post: 09-28-2011, 03:00 PM
  2. Question: daily driver cam
    By boosted z in forum Internal Engine
    Last Post: 07-04-2008, 11:44 PM
  3. Philly...is Corvette a good daily driver in the winter?
    By djvaly in forum Eastern Members
    Last Post: 12-09-2007, 03:25 PM
  4. Time to look for a good daily driver.
    By Cerwin Vega Fan in forum Almost Anything Goes
    Last Post: 04-11-2007, 05:41 AM
  5. 1993 Toyota Pickup -- good daily driver
    By jedblanks in forum Vehicles For Sale / Trade
    Last Post: 06-15-2006, 04:38 PM
