09-17-2011, 05:34 PM #1
Good idea for performance/daily driver? 02 LS1
I'm looking to spend around $2000-2500, trying to spend it as wisely as possible...
This is ROUGHLY what I was considering, numbered by priority:
1. Punisher Pro-street 3200 stall
2. SLP 3.73 gears
3. Comp cam kit (228/232 cam, lifters, pushrods, springs, timing chain, etc.)
4. Walbro LPH 255 pump
5. FAST 36lb injectors
I beleive I should be pretty close to my budget. Is this a good route to go for performance/daily driver? Any vendor recommendations are appreciated as well..
09-17-2011, 05:40 PM #2
What is done to the car? any suspension upgrades?
Give info about your ride so that people can put an input in to help you!
09-17-2011, 06:06 PM #3
sorry, info is in sig, not sure why it's not showing up...
Mods: pacesetter headers-bilstein shocks/eibach springs-K&N intake-ram air
09-17-2011, 06:15 PM #4
Really IMHO your first add-on before the stall would be subframe connectors! these cars flex under stock power and adding a higher stall will cause it to flex even more!
everyone says build your suspension before you build power(that is recommended)
but your list is good
1.SFCs
2.Stall with trans cooler
3.Gears(also the 10 bolts in our cars are very weak rebuilding them is a waste of money 12bolt or 9" is highly recommended but will force you out of your budget)
4.Cam
ect.....
others will chime in and be able to give more advice aswell!
09-17-2011, 06:34 PM #5
appreciate the advice. SFCs make sense. Is the 12bolt mod easier than the 9" overhaul?
09-17-2011, 06:44 PM #6
09-18-2011, 03:02 PM #7
Will a 2pt SFC suffice for my application? The 3pt is about double the price. I understand they're more durable, but are 3pt SFCs necessary for a 400-425whp application?
09-18-2011, 04:13 PM #8
3-points are stronger... but you should be fine with 2 points i have 2points on my car right now and they made a world of difference!
09-28-2011, 03:00 PM #9Former Mopar Man
- Jun 2011
- Branchville, NJ
You can go with two or three point SFC but get the weld in bars not the bold on. I have talked to many racers and everyone feels the welded connectors are the way to go. Bolts tend to loosen up and back out, a weld is good forever.
Philly...is Corvette a good daily driver in the winter?
By djvaly in forum Eastern MembersReplies: 33Last Post: 12-09-2007, 03:25 PM -
Time to look for a good daily driver.
By Cerwin Vega Fan in forum Almost Anything GoesReplies: 2Last Post: 04-11-2007, 05:41 AM -
good idea? bad idea? Fiance's Bday gift...
By third_shift|studios in forum Almost Anything GoesReplies: 25Last Post: 08-23-2006, 05:39 PM -
1993 Toyota Pickup -- good daily driver
By jedblanks in forum Vehicles For Sale / TradeReplies: 4Last Post: 06-15-2006, 04:38 PM -
Good daily driver cam?
By LWM in forum Internal EngineReplies: 12Last Post: 11-19-2005, 09:06 PM
