Results 1 to 11 of 11
    Member slade8200's Avatar
    NH
    02 SS #8850
    Pacesetter / SLP?
    The long tube Pacesetter headers are $440 and the SLP ones are $950. Is it really worth the extra money to get the SLP headers? The SLP ones are bare stainless and the Pacesetter ones are painted, right? Thanks.
    a lil slap n pickle SSee ya's Avatar
    Jun 2006
    Scottsdale, AZ
    I heard SLP makes shitty ass LT's...
    Member 01pewterZ's Avatar
    TEXAS
    Light Pewter Metallic
    2001 camaro Z28
    ive got a pair of used slp headers if your interested
    Florida
    2002 Trans Am WS6
    If you're going to spend the money, go with Kooks or QTP headers. SLP headers suck for clearance. Pacesetters are a great header if you are on a budget. Many of the members here are running pacesetters. Don't get SLP.
    NH
    02 SS #8850
    If you buy Pacesetter headers it is wise to get their off-road Y-pipe as well, yes? If you use the O/R Y-pipe, can you keep the converters?
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Quote Originally Posted by slade8200 View Post
    Thats the easiest way to do it. Although I said to hell with the stupid y-pipe setup and went with true duals with an H pipe
    The converters are directly after the manifolds, so by installing LT headers you are essentially deleting the cats. You can buy a catted Y pipe, but there's still no guarentee it would pass a visial inspection, since the cats are not supposed to be moved from their stock locations.
    NH
    02 SS #8850
    So if you get rid of the cats, then O2 simulators will be needed to pass an inspection right? In NH they don't do emissions but they do plug into the OBD2 port and check some things.
    NJ
    SGM
    1998 Trans Am WS6
    Exactly. There are 3 ways to get rid of the O2 codes - with a tune (best way IMO), with electronic O2 simms, or with screw in O2 simms.
    The electronic ones cost about $80, and aren't guraenteed to work. I've seen them throw codes on cars after being installed for a few days.
    I've personally used the scew in ones on more than a few cars, and they've worked every time. Its basically a spark plug non-fouler, you just screw it into the O2 bung and then screw the O2 sensor into the back of it. Basically relocates the O2 sensor farther away from the exhaust stream so it doesn't throw a code for catalyst inefficiency, but close enough that it still reads the exhaust gases. The best part is they are cheap, you can get them on eBay for $11.90 shipped
    If you're planning on getting a tune though, thats the way I would go, since you don't have to worry about the rear O2's at all, they don' even have to be plugged in.
    DFW
    '18 CTS-V
    '13 ZL1
    you want the ceramic coated Pacesetters...
    if you buy SLP headers you will be banned from this site...
    j/k, bro...
    install and ground clearance issues, are a couple reasons to stay away from SLP LT's...
    Senior Member Wheeler99WS6's Avatar
    indiana
    black, 05 Roush
    black, 99 T/A WS.6
    I too have heard SLP has fitment issues, I personally went with the Pacesetter ceramic coated LT's, and true duals with an X pipe. Pacesetters slipped right in. I couldnt believe how easily they went in. I helped some local guys install a couple sets of kooks and one set of QTPs. Quality of the headers were excellent but a pain in the ass to install.
    1999 T/A WS6 Black -------SOLD
    05 mustang Roush sport;
    DOB manifold, m122 SC, 47lb injectors, gt500 TB, roush TVS CAI, Detroit rocker SC grind camshafts, Mac LTs, off road x, roush off road mufflers, roush short throw shifter, kenne bell BAP, Brenspeed 93 octane tune. 479rwhp 436ftlbs SAE.
    running on empty Madcity T/A's Avatar
    Madison, WI
    2000 Pontiac Trans Am WS6
    IVe been looking at QTP LT's and then a off road y pipe or should I just go with the H-pipe?. and how easy they are to install?
    Thanks
  1. Pacesetter vs. Pacesetter QuikTrip
    By SactownHuskers in forum External Engine
    Last Post: 08-13-2010, 05:00 PM
  2. TSP ORY vs. Pacesetter
    By GottaHaveLS1 in forum External Engine
    Last Post: 04-09-2007, 04:58 AM
  3. Pacesetter LTs
    By Vertiviper in forum Firebird / WS6
    Last Post: 04-17-2006, 08:46 AM
  4. Pacesetter vs. Jet hot Lt's
    Last Post: 01-28-2006, 12:06 PM
  5. Pacesetter vs. Jet hot Lt's
    Last Post: 01-25-2006, 11:11 AM
