08-09-2010, 10:26 AM #1Blackshirt Member
- Aug 2009
- Lincoln, Nebraska
Black- 2001 Trans Am WS6 M6
Pacesetter vs. Pacesetter QuikTrip
Is the only difference between the two that normal Pacesetters headers are street legal and the QuikTrip are meant for offroad or racing? I don't believe I have visual emission tests in my state (NE) so not sure it would matter either way. Also, does anyone know if I go with quiktrips, do the match up with a catted y as well as ory or do they only match with an ory?
Half cocked, Full Throttle!
2001 Black Trans Am WS6 M6
1986 383 Stroker Red Chevrolet Camaro
2006 Blue Kawasaki ZX6R 636
08-09-2010, 10:33 AM #2Member
- Nov 2009
- Norfolk, Nebraska
- 2002 Camaro Z28
Get the non emissions set. I would delete the air pump and go catless if I were you. since you will need a tune anyway they can tune out the air pump, the engine bay looks much better plus the install is easier without the air lines. I have heard bad things about the pacesetter y pipes when it comes to sound.
Junkyard bought and "refurbished" 2002 Camaro Z28 - Pacetter Race LT's, TS&P ORY, Frost tune, Magnaflow, Ported TB, SLP Lid, Circle D 3000, 3.73's, SFC's.
2009 Silverado Z71 - Magnaflow
2008 Impala LTZ - Wife didn't want the V8 SS!
08-09-2010, 10:43 AM #3Blackshirt Member
- Aug 2009
- Lincoln, Nebraska
Ok, I might check out TSP then. I plan on getting a frost tune after all of this. Will I have to remove the air pump from the engine bay if I go with the ones with no EGR? Or will frost just tune all of it out? Also, will this remove O2 sensors or will those still be used?
08-09-2010, 10:48 AM #4Member
- Nov 2009
- Norfolk, Nebraska
- 2002 Camaro Z28
you will need the front o2 sensors. And its not hard to remove the air pump assembly. Also an 01 doesn't have EGR so you will be good there.
08-09-2010, 11:00 AM #5Blackshirt Member
- Aug 2009
- Lincoln, Nebraska
Ok. Any catless y with offroad headers will have hookups for the front 02 sensors correct?
08-10-2010, 12:36 PM #6Member
- Nov 2009
- Norfolk, Nebraska
- 2002 Camaro Z28
08-11-2010, 09:01 PM #7
08-13-2010, 04:58 PM #8
You will need o2 harness extensions for them to reach unless you buy the o2's for the vette with the longer harness built in them.
08-13-2010, 05:00 PM #9
Pacesetter / SLP?
By slade8200 in forum External EngineReplies: 10Last Post: 07-19-2007, 12:03 PM -
TSP ORY vs. Pacesetter
By GottaHaveLS1 in forum External EngineReplies: 5Last Post: 04-09-2007, 04:58 AM -
Pacesetter LTs
By Vertiviper in forum Firebird / WS6Replies: 2Last Post: 04-17-2006, 08:46 AM -
Pacesetter vs. Jet hot Lt's
By GottaHaveLS1 in forum External EngineReplies: 19Last Post: 01-28-2006, 12:06 PM -
By GottaHaveLS1 in forum External EngineReplies: 0Last Post: 01-25-2006, 11:11 AM
