    Puerto Rico LS1 Rikki_SeVeN's Avatar
    Puerto Rico
    1999 Camaro Z28 A4
    Lowerd Car... Lower Control Arms???
    ok guys...so... the Eibachs and UMi Adjustable Panhard are on their way...and well... what about the control arms?
    I was told that I'd need drop brackets for them... but would adjustable ones do the trick without having to weld anthing???
    Thanks for the help!
    Mods: SLP Air Lid w/ KN, Free-Mods, LS6 Manifold, Magnaflow, Headers, EFILive
    Visuals: Angel eyes, rear eurolights and T/A rims
    Suspension: Eibach ProKit, UMI Adj. Panhard, SFC's, LCA Relocation brakets, KYB AGX shocks
    http://www.fquick.com/garages/Chevro...28/1999/23674/
    Puerto Rico
    1999 Camaro Z28 A4
    any help at all really... and um.. with some... relocation brackets... will it be hitting everything I drive over?
    Senior Member JonB's Avatar
    Florida
    2005 GTO
    You need the brackets. Well you don't need them but they are suggested for optium traction. Adjustable lcas will not fix the angle. There should be a downward angle on the lca's when you lower the car you lose that. Adjustable lca's you can increase or decrease the total length of the lca, it does not change the angle the lca is at.
    05 PBM GTO
    Cold Air Inductions CAI,
    Relocated IAT with omega,
    Slp Predator tune,
    Flowmaster axle back with H pipe,
    Custom tuned TCM.
    BC Racing coil overs
    Sold 01 z28
    Earth
    Also, you don't have to buy weld-on LCA brackets. I bought the bolt-on brackets and they work fine. You can always have the bolt-on brackets welded at a later time if you want but the way the bolt-ons attach, I can't see how they would work loose.
    Puerto Rico
    1999 Camaro Z28 A4
    thanks guys... really appreciated... I would've probably ended up making a mistake...
    keep in mind, you WILL have to cut through the existing LCA bracket b/c the brake lines run through it-there is no place for the brake lines to run on the new brackets...zip tie
    Puerto Rico
    1999 Camaro Z28 A4
    really?... didn't know that... that applies for the bolt in ones too?
    oh yeah... what about clearance... I mean will the lca's hit anywhere?
    I have the bolt-ons, almost had them in until i got all hung up on the beak line...i would assume they don't hit as much since they are literally traveling the same course as the tires-unlike when you straddle a bump between your front/rear and your exhaust bounces off it
    Earth
    Some sellers recommend just cutting one side of the parking brake cable bracket away. You really only need it fastened on one side of the LCA mount. I was able to reform my parking brake bracket so it wraps around the new relo bracket. It was difficult and time consuming doing it the way I did; using a 3 lb hammer and several different pry bars and screw drivers. Essentially I ended up stretching and re-molding the bracket. I will take and post a picture if you think that will help.
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    avoid polyurethane LCA unless it's purely a drag car... will corner worse w/ poly than w/ stock rubber.
    Eugenio_SS
    Earth
    You are referring to straight bushings. At least two manufacturers make an articulating ball and socket joint. The socket is a softer poly while the inner ball is hard. J&M Products sells the patent pending polyurethane jointed LCAs that give good rotation without bind.
    Puerto Rico
    1999 Camaro Z28 A4
    THE EIBACHS ARE HERE!!!...YAY!!!... too bad I'm gonna have to wait another month to put them on...LOL...
    need the Adjustable Panhard... the LCA braket... and Shocks!... LOL... damn if I didn't run out of money...cause of that Body Brace I found was missing from my car....
  1. BMR front LOWER CONTROL ARMS / A-Arms
    By 97ramsst in forum Parts For Sale / Trade
    Last Post: 12-15-2010, 05:59 AM
  2. Lower Control Arms
    By bow125106 in forum Parts Wanted / Trade
    Last Post: 03-15-2009, 04:23 AM
  3. Lower control arms
    Last Post: 03-13-2009, 10:51 AM
  4. lower control arms
    By 346ci in forum Suspension and Handling
    Last Post: 03-24-2008, 08:09 AM
  5. Lowerd Car... Lower Control Arms???
    By Rikki_SeVeN in forum Suspension and Handling
    Last Post: 07-20-2007, 03:52 PM
