Results 1 to 2 of 2
07-17-2007, 01:30 PM #1
Lowerd Car... Lower Control Arms???
ok guys...so... the Eibachs and UMi Adjustable Panhard are on their way...and well... what about the control arms?
I was told that I'd need drop brackets for them... but would adjustable ones do the trick without having to weld anthing???
Thanks for the help!
07-20-2007, 03:52 PM #2
what you need is relocation brackets for the trailing arms.
http://vincihighperformance.com/fbod...rent.html#REAR
BMR CONTROL ARM RELOCATION KIT
Reposition your instant center by altering your control arm angle for increased traction . Made from strong 3/16" laser cut, cold rolled steel. Both versions will lower the rear of the control arms up to 3" and work with all makes of control arms. A must for lowered vehicles to reclaim lost control arm angles.
CAB002
BOLT-IN
129.95
BMR front LOWER CONTROL ARMS / A-Arms
By 97ramsst in forum Parts For Sale / TradeReplies: 4Last Post: 12-15-2010, 05:59 AM -
Lower Control Arms
By bow125106 in forum Parts Wanted / TradeReplies: 1Last Post: 03-15-2009, 04:23 AM -
Lower control arms
By bow125106 in forum Parts Wanted / TradeReplies: 0Last Post: 03-13-2009, 10:51 AM -
lower control arms
By 346ci in forum Suspension and HandlingReplies: 8Last Post: 03-24-2008, 08:09 AM -
By Rikki_SeVeN in forum Suspension and HandlingReplies: 11Last Post: 07-27-2007, 06:21 AM
