Results 1 to 20 of 32
Thread: im out of ideas
    oceanside ca
    06 GTO
    im out of ideas
    about a week ago my car started hesitating real bad, now when i am driving it, even at wot, it feels like i am letting off the gas. i dont really know how to explain it, but it will run just fine, then out of nowhere it starts doing it. i just changed the fuel filter and the spark plugs and wires are only a few months old. i just cant figure out what it is. if you have any ideas or questions let me know.
    97 t/a
    Magnaflow catback, K&N FIPK, chrome 17x9.5 zr1's, 3.42 gears, full pioneer sound system
    cavpat; 100 the first race, he wanted to go AGAIN for another $100? LMFAO
    What do you tell a ricer that's out $200?
    ...Nothin, you done told him twice! LOL
    Georgia
    2014 Camaro 1LS
    maybe water in the gas ???
    oceanside ca
    06 GTO
    i ran the tank out when i changed my filter, i just got back from gassing it up again, i put about 30 miles on it when i put the new gas in it. thanks for the help though.
    Georgia
    2014 Camaro 1LS
    Quote Originally Posted by ice97ta View Post
    if it were me b4 I did anything major I would run some fuel injector cleaner through it
    oceanside ca
    06 GTO
    i will try that, ill do it today then its getting parked until i get some more ideas.
    oceanside ca
    06 GTO
    now it seems as if it only does it when i turn right, it will do it all through straights after a right turn, then magically it will stop.
    Georgia
    2014 Camaro 1LS
    some other guys will see this and maybe have some other ideas .....gl
    oceanside ca
    06 GTO
    thanks
    Junior Member Steve L's Avatar
    Feb 2007
    Arizona
    Did the injector cleaner make any difference?
    If turning just one way causes it, it seems like it is a fuel flow problem. In the older T/A's ('70-80's) they used to have a sock filter in the gas tank itself...do the new ones also? If it does, that might be the problem. They had a tendancy to get clogged, or get sucked up into the line and cause hesitation like you are feeling.
    Just a stab in the dark.
    oceanside ca
    06 GTO
    havent been able to run it through yet, will try tonight. talked to a friend, he thinks it might be the Mass airflow sensor but i will try anything right now.
    houston
    2001 ws6 trans am ramair
    its the mass air
    oceanside ca
    06 GTO
    i sure hope your right, i ran some injector cleaner through it and nothing changed, so i am going to try the MAF now
    EL PASO TX.
    NAVY BLUE METALLIC
    02' WS6 TRANS AM
    If it does that when you step on the gas pedal then it might even be your fuel pump. That happened to me a while back it felt like if it would go dead whenever i floored it!
    MOTOR CITY MARO' SSTODD's Avatar
    LIVONIA,MICHIGAN
    PEWTER
    2000 CAMARO SS #3821
    The dreaded opti-spark maybe??? They have a notorious reputation.
    oceanside ca
    06 GTO
    Quote Originally Posted by SMOKIN WS6 View Post
    the thing is that it does it no matter how hard or soft i push the pedal.
    Member Bouvers's Avatar
    Blue 1997 Trans Am(Sold)
    Pewter 2001 Trans Am Vert
    I would go with MAF before anything, I don't think its the optispark from my experience I feel that they only tend to hesistate like that at very high rpms not down low. However, I'm also saying that because optispark is an expensive fix and i'd try a few other things first. good luck keep us up to date.
    oceanside ca
    06 GTO
    i will definitatly let you guys know what it is when i fix it, thanks.
    Member Rob00Taws6's Avatar
    Southern Maryland
    2000 pontiac trans am
    Your problem definitely sounds electronic in nature. Personally I have never worked on an OBD II LT1. But I did have a similar problem with my 89 GTA. I had changed the cam and went with a lingenfelter/accel plenum, runners, and intake manifold. A check engine light popped up and the code was for a burn off relay for the MAF. So I changed the relay, and not to soon after my MAF kicked the bucket. So I dropped the money and changed it. About three days after changing it I would get these sudden burst of hesitation when the car was cruising and when I held the RPMs at a constant level. The RPMs would oscillate, the worst thing was that there was no codes or engine light so, I had no clue to what was fouling out. So after checking for a vacuum leak and changing out O2 sensors, and TPI sensors I went back to the MAF sensor, went back to the parts store to find out that I was given a sensor calibrated for a 6 cylinder car. I went to a granatelli MAF sensor for a l98, a bear to adjust but a good product, and the car ran well. Honestly, I would check for a vacuum leak, and then go through your sensors, something has to be fouled up and giving the computer a wrong reading, I would even check your connection for your sensors make sure there is no corrosion in the wiring.
    oceanside ca
    06 GTO
    thanks for the insight, i will be getting a new maf tomorrow so i will do that first and see what happens
    Member cailey37's Avatar
    Mississippi
    1998 Pontiac Trans Am
    From what you're saying I dont think it's the MAF......to me I'd be leaning more towards the Opticrap. How longs it been since you did anything with it????? And since you live in a coastal city that nice salt air you have will do wonders on the opti.........take a look at that...
  1. ideas?
    By suede in forum Almost Anything Goes
    Last Post: 01-28-2010, 10:59 PM
  2. Ideas...
    By rajiv1998 in forum Almost Anything Goes
    Last Post: 12-18-2008, 12:04 PM
  3. any ideas????
    By Boomer Sooner in forum Almost Anything Goes
    Last Post: 08-03-2008, 12:30 AM
  4. Any ideas???
    By Z28_SS in forum Camaro / SS
    Last Post: 03-09-2007, 06:44 AM
  5. Any Ideas???
    By greatwhitess in forum Internal Engine
    Last Post: 07-03-2006, 01:36 PM
