Results 1 to 15 of 15
    Member blackls1ta's Avatar
    kittanning,pa
    2000 ws.6 m6
    how much hp can a stock bottom end take safely?
    can i accomplish 525 rwhp on stock bottom end?pistons,rods, crank,etc?
    Yes.
    Tune plays a HUGE role in that.
    kittanning,pa
    2000 ws.6 m6
    Yes.
    how much do you think this will cost to run 525 hp?
    kittanning,pa
    2000 ws.6 m6
    5k?
    Depends on how you set it up.
    Probably more than $5K though.
    kittanning,pa
    2000 ws.6 m6
    id like to just do heads ,cam
    Member sfletch2000's Avatar
    Feb 2007
    Bakersfield, CA
    86 Buick Grand National
    02 WS6-M6 407 RWHP
    Well you won't hit 525 like that 450-480 is the norm
    kittanning,pa
    2000 ws.6 m6
    Quote Originally Posted by sfletch2000 View Post
    that wud work with my budget,450-480 not bad
    Heads, cam, and bolt-ons tend to make 425 RWHP.
    Feb 2007
    Bakersfield, CA
    02 WS6-M6 407 RWHP
    Check out my sig i spent about 2500 for parts roughly, i'm gonna do heads next -PRC LS6 Heads, Gaskets, Head bolts, and another dyno tune and that will run me about another 1600 so that kinda gives you an idea but that all depends if you decide to go with the budget stuff or the expesive stuff.
    Well Mr. Lous my combo is pretty basic and i should hit 450 with heads and i have a pretty mild cam compared to most. But for auto i'd say 425 is expected.
    Pacesetter Headers- ORY
    Texas Speed 228R Cam/Moly Pushrods/918 Springs
    MTI LID
    Slp Under Drive Pulley
    Texas Speeds Rumbler Catback
    SFC's, Lakewood LCA's
    Koni SA 4/3, Strano Springs
    Dyno Tune
    LS7 Clutch, Nitto DR's
    407 RWHP 377 Ft./lbs.
    orlando
    if u want that power check out some cam only 150 shot setups with a bad ass tune and ur set
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    well you ask how much power can it take safely, i wouldnt go past 425 or so personally on a stock bottom end
    a few bolt ons, 379 rwhp
    11.96 @113.25
    kittanning,pa
    2000 ws.6 m6
    i was thinkin 225 mongoose heads with comp cam xtrreme energy 265
    Jesus died to save you! Killer_bluebird's Avatar
    North Olmsted, OH
    Quote Originally Posted by blackls1ta View Post
    Small Bore 225 will not work that great on a stock cubed LS1 imho. Low end will suck compared to other combos. You are better of with a Trickflow 215cc set of heads and a healthy cam in the 239-240 range. Maybe something like Patrick's cam (on LS1Tech) or a custom ground MS4 on a 110 LSA+4 should put nice number with good torque. You should check P2V but unshaved 215's have better P2V than stock due to the 15* valve angle, so you may not need to flycut. That should net you around 460-470rwhp on a M6 with all the other bolt ons and 480+ with a ported 90/90 combo. That is how Vengeance racing have been cranking out NA cars in the 480-510rwhp range.
    2000 NBM Camaro Z28
    Mods:
    SLP Lid & K&N, AHR Headers + 3" catted Y and Mangaflow, !EGR, !AIR, BMR CM STB, ST Front 35mm and Hellwig Adj. Rear 22mm Swaybar, Adj. Rod/Rod PHB, Koni SA's, Ground Control Springs & Adj. Ride height, and HPTuners.
    Member danziger's Avatar
    Aug 2006
    Chesapeake, VA
    Le Mans Blue
    2004 Z16
    I subjected my stock-bottom to 576rwhp/590rwtq with heads/cam/100shot and it lasted for a few years before pushing a head-gasket. These engines are pretty tough... Anyways, 500+rwhp is not a cheap or easy proposition for a heads/cam car. Most GOOD set-ups are in the 450rwhp range. Mine was GOOD for 2002 and made 436/420 with a nitrous cam. Of course that was before AFR, Dart, ETP, etc heads, but you get the idea. When I pushed the head-gasket, I decided to go with a forged 383, but my internals looked fine, so I'd honestly recommend heads/cam/small shot to achieve your goals.
  1. Stock bottom end
    By Darkrider02 in forum Camaro / SS
    Last Post: 09-14-2010, 11:04 AM
  2. WTB-98-02 ram air stock air box. both top and bottom!
    By shady milkman in forum Parts Wanted / Trade
    Last Post: 06-08-2007, 10:07 AM
  3. How much power can stock LS1 block safely handle?
    By svtben in forum Forced Induction
    Last Post: 03-29-2007, 02:00 PM
  4. stock bottom end
    By sszcam in forum Nitrous
    Last Post: 06-02-2006, 02:39 PM
