Results 1 to 2 of 2
Thread: Stock bottom end
09-14-2010, 08:37 AM #1
Stock bottom end
Thinking about getting some prc 5.3l heads and a streetable cam then all of a sudden I thought about getting the maggie s/c after I get the heads and can.... Question is will the block hold probably run the s/c low boost
09-14-2010, 11:04 AM #2
8psi is what is recommended on a stock bottom end. Any higher boost levels than that and you have to start worrying.
The block itself will hold longer than the stock pistons.
Stock bottom end capacity
By Darkrider02 in forum General HelpReplies: 0Last Post: 11-04-2010, 05:03 PM -
how much hp can a stock bottom end take safely?
By blackls1ta in forum Internal EngineReplies: 14Last Post: 07-11-2007, 06:10 AM -
WTB-98-02 ram air stock air box. both top and bottom!
By shady milkman in forum Parts Wanted / TradeReplies: 7Last Post: 06-08-2007, 10:07 AM -
stock bottom end
By sszcam in forum NitrousReplies: 12Last Post: 06-02-2006, 02:39 PM
