Results 1 to 3 of 3
    Member firemedic0135's Avatar
    East Texas
    2000/Trans Am
    Gear swap question? Please help
    My current setup is stock and is whining pretty bad.I want to rebuild the rear and swap gears from the current 2.73 with a 2 series carrier to a 3.73.
    I have read somewhere that you need a specific ring & pinion gear for the 2 series carrier.I also read that a spacer can be used for the 2 series carrier.
    Due to my ignorance about rear ends (on cars) I am really wadding through a ton of info trying to figure out what the hell I need.I wouldnt know a 2 series carrier from a 3 series carrier if they hit me in the head
    Thanks again in advance for those that take the time to get me on the right track.
    Member cailey37's Avatar
    Mississippi
    1998 Pontiac Trans Am
    It is my understanding that you need a 3-series carrier for the 3.73's.....unless of course someone has developed a 2-series carrier that will work....just haven't heard of one.....I could be wrong but I just haven't heard of it
    TN
    2005 GTO M6 Black
    2000 Z28 A4 Red
    You can put a 3.73 gear on a series 2 Carrier "IF" you use a spacer and you have a series 2 in yours. A 3.73 is thinner than the 2.73 so you have to make up for it with the spacer or find a series 3 Carrier which came in cars with 3.23 or numerically higher gears all M6 cars had 3.42 (series 3) and some autos had 3.23 (series 3). 3.08 and down numerically are series 2. There is no "special" gear you just need to use a spacer with 3.73's. If you get a 3.08 it will just go right in but that wouldn't be worth the time/cost to replace.
  1. Gear swap
    By Al Hazz in forum Drivetrain
    Last Post: 06-25-2008, 08:21 PM
  2. ok gear swap question?
    By camarostripes96 in forum LT1
    Last Post: 06-01-2008, 06:42 PM
  3. considering gear swap
    By 02WS6dream in forum Automatic Transmission
    Last Post: 01-06-2007, 04:27 PM
  4. Gear swap
    By Wheeler99WS6 in forum Drivetrain
    Last Post: 11-18-2006, 09:03 PM
  5. 3.73 gear swap
    By mrdavid in forum Manual Transmission
    Last Post: 06-09-2006, 11:16 AM
