Thread: Compression?
07-02-2007, 02:34 PM #1
Compression?
I Am Looking To Do A 383 Lunati Stroker For My Ls1 What Is The Deal With The Different Compresions For The Rotating Assembly? I Always Thought That It Was The Cam And Heads That Determined The Compression
1998 Trans Am Vert, M6, Soon to be full of goodies......
07-02-2007, 02:38 PM #2Slow'er'Ass
- Thornton, CO
Cam helps determine dynamic compression. How much compression gets 'bleeded' off because of the overlap.
Pistons and heads determine static compression. The cylinder compression without overlap.
07-02-2007, 02:43 PM #3
If I Am Doing A Forged Bottom End Will The Compression Matter? I Am Going To Do A Sts Kit On Top Of It All, Would It Need To Be The Lower 8:5 Or Could I Get More Hp From Doing 10:1 Comp Ratio?
07-02-2007, 02:53 PM #4Slow'er'Ass
- Thornton, CO
I think your caps lock button might be on.
The STS system can't high really high boost numbers. 9:1-9.5:1 would be ideal I would think.
Probably get better answers in the forced induction section.
compression
By SIERA*123 in forum General HelpReplies: 0Last Post: 09-13-2008, 06:40 AM -
Compression
By SIERA*123 in forum GM TrucksReplies: 0Last Post: 09-13-2008, 06:04 AM -
compression
By 00ssls1 in forum Internal EngineReplies: 0Last Post: 05-28-2008, 07:18 AM -
compression
By fastbuff in forum General HelpReplies: 6Last Post: 12-16-2006, 12:18 PM -
At what compression
By Mr. Luos in forum Internal EngineReplies: 8Last Post: 06-24-2006, 08:05 AM
