    At what compression
    Should you run a colder plug?
    Senior Member ninobrn99's Avatar
    Aug 2003
    Honolulu HI
    all bore 370 Trans Am
    I dont think its soley based on compression, static or dynamic. I think octane, power, and your H/C combo should be taken into consideration. Personally, I think once you reach over 400hp your running the motor harder and valve events change dramatically with a cam swap. In my cam only ls6 (for the most part a ls6 ) Im running the tr55's, but I think I should go ahead and throw the tr6's in there. When I get my new motor, I will be running tr6's based on all these factors. Id like to give you numbers, but that could easily contridict what I just said. You could easily have a DCR of 8.4ish, SCR of 10.2 and be making over 400rwhp...with your setup, Id try the tr6's and see how they work out for ya.
    Member 408WS6's Avatar
    Houston
    Current best: 10.60/126.8
    1998 Pontiac TA WS6
    I got tr6s and like 'em
    Did you ever run with TR55's??
    Thinking about just getting the TR6's and trying them out.
    Lowered, HID's, tinted.
    Aug 2003
    Honolulu HI
    Ive been running tr55's. Ive been meaning to swap over to the tr6's, but just didnt find time. With my new motor going in in august, Im using the tr6's.
    What compression are you guys running?
    Aug 2003
    Honolulu HI
    just over stock on the current motor because I went with ls6 heads, but with the new motor, Ill be running 11.1 scr and about 8.4 dcr. Few other guys I know running Tr6's are running anywhere from stock compression to 11.4. .
    11:1 for me scr.
    Suppose it wouldn't hurt eh?
    Aug 2003
    Honolulu HI
    nope.
  1. compression
    By SIERA*123 in forum General Help
    Last Post: 09-13-2008, 06:40 AM
  2. Compression
    By SIERA*123 in forum GM Trucks
    Last Post: 09-13-2008, 06:04 AM
  3. compression
    By 00ssls1 in forum Internal Engine
    Last Post: 05-28-2008, 07:18 AM
  4. Compression?
    By schrysler in forum Internal Engine
    Last Post: 07-02-2007, 02:53 PM
  5. compression
    By fastbuff in forum General Help
    Last Post: 12-16-2006, 12:18 PM
