    Member Blackout's Avatar
    austin, tx
    2002 Mustang GT
    You only think u no what acceleration is
    * One Top Fuel dragster 500 cubic-inch Hemi engine makes more horsepower than the first 4 rows at the Daytona 500.
    * Under full throttle, a dragster engine consumes 11.2 gallons of nitro methane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced.
    * A stock Dodge Hemi V8 engine cannot produce enough power to merely drive the dragster's supercharger.
    * With 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition. Cylinders run on the verge of hydraulic lock at full throttle.
    * At the stoichiometric 1.7:1 air/fuel mixture for nitro methane the flame front temperature measures 7,050° F.
    * Nitro methane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
    * Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
    * Spark plug electrodes are totally consumed during a pass. After 1/2 way, the engine is dieseling from compression plus the glow of exhaust valves at 1,400° F. The engine can only be shut down by cutting the fuel flow.
    * If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half.
    * Dragsters reach over 300 MPH before you have completed reading this sentence.
    * In order to exceed 300 MPH in 4.5 seconds, dragsters must accelerate an average of over 4 G's. In order to reach 200 MPH well before half-track, the launch acceleration approaches 8 G's.
    * Top Fuel engines turn approximately 540 revolutions from light to light!
    * Including the burnout, the engine must only survive 900
    revolutions under load.
    * The redline is actually quite high at 9,500 RPM.
    * THE BOTTOM LINE: Assuming all the equipment is paid off, the crew worked for free, & for once, NOTHING BLOWS UP, each run costs an estimated $1,000 per second.
    The current Top Fuel dragster elapsed time record is 4.441 seconds for the quarter-mile (10/05/03, Tony Schumacher). The top speed record is 333.00 MPH (533 km/h) as measured over the last 66' of the run (09/28/03, Doug Kalitta).
    Putting this all into perspective:
    You are driving the average $140,000 Lingenfelter twin-turbo powered Corvette Z06. Over a mile up the road, a Top Fuel dragster is staged & ready to launch down a quarter-mile strip as you pass. You have the advantage of a flying start. You run the 'Vette hard up through the gears and blast across the starting line & pass the dragster at an honest 200 MPH. The 'tree' goes green for both of you at that moment.
    The dragster launches & starts after you. You keep your foot down hard, but you hear an incredibly brutal whine that sears your eardrums & within 3 seconds, the dragster catches & passes you. He beats you to the finish line, a quarter-mile away from where you just passed him. Think about it - from a standing start, the dragster had spotted you 200 MPH & not only caught, but nearly blasted you off the road when he passed you within a mere 1,320 foot long race!
    That's acceleration!
    Senior Member
    Newport, RI
    '00 Formy A4
    Wow, be great to have one of those on Pinks.
    "You want 30 car lengths? No problem!"
    Super Senior Member derrinx's Avatar
    Feb 2006
    NYC
    2000 Trans Am WS6
    haha very interesting!
    Member tornado's Avatar
    Pa
    Blue
    2004
    Top fuel is great,going to bristol next week
    SCPO - Retired joerockhead's Avatar
    Mile High
    BlackCherry
    Bad Ass 67 Camaro / 2010
    Mile HIgh Nationals - July 13th
    Section 3, Row A, seats 6/7/8
    I will have my Digital camera dn my Video camera!
    no more 4th gen secondgearscratch's Avatar
    Jun 2006
    St. Louis, Missouri
    2000 z28
    i had this email a few years ago. i used the info when i want to show off....
  1. Acceleration
    By BDowning in forum Multimedia Section
    Last Post: 02-16-2011, 05:50 AM
  2. Acceleration
    By BDowning in forum Almost Anything Goes
    Last Post: 07-13-2009, 06:10 AM
  3. A Lesson in Acceleration
    By ls1verbullet in forum Almost Anything Goes
    Last Post: 04-30-2008, 08:19 PM
  4. acceleration at WOT
    By totalkos in forum General Help
    Last Post: 11-25-2007, 12:01 PM
  5. 99 ls1 stumbles on acceleration
    By 99blackLS1 in forum Firebird / WS6
    Last Post: 05-03-2007, 08:34 PM
