Thread: Acceleration
    Member BDowning's Avatar
    Milford, Ohio
    Blue
    2002 WS-6
    Acceleration
    DEFINITION OF ACCELERATION
    One top fuel dragster 500 cubic inch Hemi engine makes more horsepower
    than the first 4 rows of stock cars at the Daytona 500.
    It takes just 15/100ths of a second for all 6,000+ horsepower of an NHRA
    Top Fuel dragster engine to reach the rear wheels.
    Under full throttle, a dragster engine consumes 1-1/2 gallons of nitro
    methane per second; a fully loaded 747 consumes jet fuel at the same rate
    with 25% less energy being produced.
    A stock Dodge Hemi V8 engine cannot produce enough power to drive the
    dragster's supercharger.
    With 3,000 CFM of air being rammed in by the supercharger on overdrive,
    the fuel mixture is compressed into a near-solid form before ignition.
    Cylinders run on the verge of hydraulic lock at full throttle.
    At the stoichiometric (stoichiometry: methodology and technology by
    which quantities of reactants and products in chemical reactions are
    determined) 1.7:1 air/fuel mixture of nitro methane, the flame front
    temperature measures 7,050 deg F.
    Nitro methane burns yellow. The spectacular white flame seen above the
    stacks at night is raw burning hydrogen, dissociated from atmospheric water
    vapor by the searing exhaust gases.
    Dual magnetos supply 44 amps to each spark plug. This is the output of
    an arc welder in each cylinder.
    Spark plug electrodes are totally consumed during a pass. After
    halfway, the engine is dieseling from compression, plus the glow of exhaust
    valves at 1,400 deg F. The engine can only be shut down by cutting the fuel
    flow.
    If spark momentarily fails early in the run, unburned nitro builds up in
    the affected cylinders and then explodes with sufficient force to blow
    cylinder heads off the block in pieces or split the block in half.
    In order to exceed 300 mph in 4. 5 seconds, dragsters must accelerate an
    average of over 4G's. In order to reach 200 mph (well before half-track),
    the launch acceleration approaches 8G's.
    Dragsters reach over 300 miles per hour before you have completed
    reading this sentence.
    Top fuel engines turn approximately 540 revolutions from light to light!
    Including the burnout, the engine must only survive 900 revolutions under
    load.
    The redline is actually quite high at 9,500 rpm.
    Assuming all the equipment is paid off, the crew worked for free, and
    for once NOTHING BLOWS UP, each run costs an estimate $1,000.00 per second.
    The current top fuel dragster elapsed time record is 4.428 seconds for
    the quarter mile (11/12/06, Tony Schumacher, at Pomona , CA ). The top speed
    record is 336.15 mph as measured over the last 66' of the run (05/25/05 Tony
    Schumacher, at Hebron , OH ).
    Putting all of this into perspective:
    You are driving the average $140,000 Lingenfelter 'twin-turbo' powered
    Corvette Z06. Over a mile up the road, a top fuel dragster is staged and
    ready to launch down a quarter mile strip as you pass. You have the
    advantage of a flying start. You run the 'Vette hard up through the gears
    and blast across the starting line and pass the dragster at an honest 200
    mph. The 'tree' goes green for both of you at that moment.
    The dragster launches and starts after you. You keep your foot down
    hard, but you hear an incredibly brutal whine that sears your eardrums and
    within 3 seconds, the dragster catches and passes you. He beats you to the
    finish line, a quarter mile away from where you just passed him.
    Think about it, from a standing start, the dragster had spotted you 200
    mph and not only caught, but nearly blasted you off the road when he passed
    you within a mere 1,320 foot long race course.
    ... and that my friend, is ACCELERATION!
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    i got that in a email awhile ago..it was a great read..this should probbally be in the AAGs section tho
    Milford, Ohio
    Blue
    2002 WS-6
    I wasn't sure where to put it??????
    Shepherd, Michigan
    98' trans am
    its all good...
    the fuel mixture being near solid form right before combustion is amazing
  1. Acceleration
    By BDowning in forum Multimedia Section
    Last Post: 02-16-2011, 05:50 AM
  2. A Lesson in Acceleration
    By ls1verbullet in forum Almost Anything Goes
    Last Post: 04-30-2008, 08:19 PM
  3. acceleration at WOT
    By totalkos in forum General Help
    Last Post: 11-25-2007, 12:01 PM
  4. You only think u no what acceleration is
    By Blackout in forum Almost Anything Goes
    Last Post: 07-01-2007, 01:53 PM
  5. 99 ls1 stumbles on acceleration
    By 99blackLS1 in forum Firebird / WS6
    Last Post: 05-03-2007, 08:34 PM
