Results 1 to 19 of 19
    texas
    2001 formula
    Turn Signal Bulb Replace?
    I hope this don't sound too dumb but my drivers side front turn signal/day time running light is burned out. I looked at the lens from the front and I see no screws in the lens. I am assuming i have to jack up the car to get it out? It is a 2001 formula. Thanks for the info.
    There are plastic panels underneath of the car.
    I believe they are 10mm bolts holding a flap up. Remove those and you should have access to the back side of the blinker housing.
    400rwhp::370rwtq Lucky 13's Avatar
    Little Elm, TX
    2002 T/A WS.6 -- ASC#12
    i just stuck my hand in through the slit under the light and twisted it out from there
    texas
    2001 formula
    Thanks guys. If it ever quits raining here I will crawl under and find the panel.
    Georgia
    2014 Camaro 1LS
    much easier to go through the panel under the car not unless u got super skinny arms
    Senior Member rajiv1998's Avatar
    New Jersey
    1998 Pontiac Trans Am
    couldnt have said it better. Mine kept burning out so i was underneath there every other week. Then finally my whole fucking socket burned out.
    Senior Member Hurley711's Avatar
    Earth
    414 RWHP 395 RWTQ
    00 Black Ram Air Trans Am
    same here as above, reach through the skinny opening under the lights
    Member Mike's TA's Avatar
    Austin, TX
    99 Trans Am(sold)
    Don't forget to add Bulb Grease. Water will get in the light, that's what caused it to blow. Bulb grease will make it last longer. Until you burn out the socket.
    Junior Member Steve L's Avatar
    Feb 2007
    Arizona
    Also check and see if you have developed cracks in the lens itself. Both of mine had hairline cracks so every time it rained, I blew bulbs unknowingly. After awhile, I had to replace both sockets and applied a little clear tape on the lenses; she's all better now.
    Junior Member bigboy T/A's Avatar
    Pearland, TX
    same here my passenger side is the one that always goes out everymonth eventhough it does not rain. then it alternates to the drivers side for a month then it sitches back
    texas
    2001 formula
    Well it dried up enough today to replace the bulb. I removed the 10mm bolts. The bad part was after I removed the socket and pulled on the bulb to remove it The damn thing shattered in my hand and of course a chunk went into my thumb. Also did apply grease to socket because water did come out of it. Lesson learned next time wrap a paper towel around old bulb. Oh well got er done. Thanks for the info guys.
    Austin, TX
    99 Trans Am(sold)
    Quote Originally Posted by wnmech View Post
    Hey, What part of Texas are you in?
    texas
    2001 formula
    Grand Prairie. Its between Dallas and Fort Worth.
    Virginia
    1998 TA
    If you're getting water in the housing and blowing the bulb I'd try to fix it or eventually you're gonna need to splice in a new socket. You can either find the cracks and silicone it up or buy a new housing for around $40. Either way make sure to put some dielectric grease in the socket when you replace the bulb.
    Junior Member REDHEATWS6's Avatar
    MIAMI, FLORIDA
    RED
    2001 PONTIAC TA RAM AIR
    Same here, reach through the opening under the lights and twist. Passenger side light went out about 3 years ago and since then no problem, still functioning. This week had to change driver's side and of course it was wet. Alot of rain lately in Miami!
    Houston, Texas
    2000 C5 Torch Red
    I just spent an afternoon messing with that crap. Got tired of replacing bulbs after every rainstorm at $4 a two pack.
    I removed both of the turn signals. two 10mm bolts to open the flap and then two 7mm bolts for each signal. Once out I noticed the top had some cracks in it. The underside was all bubbly from the heat of the bulb and had cracked straight through.
    I took some JB weld and applied it to the top and underside of the top. Then ran a bead of clear silicone all around the front rim of the light (where the front clear plastic meets the rest of the assembly). I do have some hairline cracks on the clear plastic, but it doesn't go all the way thru, so I left it alone. Grabbed my vacuum cleaner and sucked all the water/moisture out. Then reinstalled and since they have been as clear as the day it rolled out.
    Junior Member dreed2's Avatar
    Cape Cod
    Metallic Navy Blue
    2001 Camaro Z28
    Thanks for asking that question...
    And thanks to all who replied. My passenger-side bulb turn signal/running light burned out and I couldn't figure out how to get at it to get it out. Now I've got it out and found out the bulbs I bought to replace it don't fit. That'll teach me to buy replacement bulbs at the supermarket!
    Last edited by dreed2; 07-15-2007 at 06:55 AM. Reason: trying to get profile picture working...
    Houston, Texas
    2000 C5 Torch Red
    hehe.... 3157NA or 3157NALL. I have 'em memorized now.
    Cape Cod
    Metallic Navy Blue
    2001 Camaro Z28
    Thanks again! I'm going to NAPA tomorrow (it's across the street from where I work).
  1. '02 turn signal bulb socket
    By johnfin in forum Firebird / WS6
    Last Post: 02-06-2013, 05:11 PM
  2. changing drl/turn signal bulb
    By buzzkill in forum Camaro / SS
    Last Post: 10-26-2009, 07:27 PM
  3. turn signal/drl bulb issue
    By 1MileCrash in forum General Help
    Last Post: 11-06-2008, 05:44 PM
  4. changing a turn signal bulb
    By URNEXT in forum General Help
    Last Post: 06-22-2006, 08:13 PM
  5. Replacing Turn signal bulb
    By LA Girl99 in forum General Help
    Last Post: 08-12-2005, 08:02 AM
