Results 1 to 3 of 3
Thread: changing a turn signal bulb
06-21-2006, 09:58 AM #1Junior Member
- Jun 2006
- Kentucky
Silver- 2000 Camaro Z28
whats the easiest way? do you have to take the headlight out to get at the turn signal? 2000 Camaro.
06-21-2006, 11:43 AM #2
Funny you should ask I just changed my L/H running light last weekend. The only way for me was from the bottom. I removed (loosened) the plastic panels just under the light and inboard of the wheel. I had to remove the bulb by feel so first did the head lamp so I would know how (which way) to turn in order to unsnap. Once the bulb receptacle is removed there is enough slack in the wire to pull the receptacle down and replace with a new bulb. Putting it back in the hole again was by feel but managed and it snaped right in. Good Luck
2000 Z28
06-22-2006, 08:13 PM #3Member
- Burlington, NC
Black- 2000 Camaro SS
That is what that drop down door in each corner of the front plastic under body panel is for.
JEB
changing drl/turn signal bulb
By buzzkill in forum Camaro / SSReplies: 20Last Post: 10-26-2009, 07:27 PM -
turn signal/drl bulb issue
By 1MileCrash in forum General HelpReplies: 11Last Post: 11-06-2008, 05:44 PM -
Turn Signal Bulb Install ?
By FireRescueWS6 in forum General HelpReplies: 2Last Post: 01-30-2008, 05:02 PM -
changing turn signal/dayrunner bulb
By c0ldwhitelite in forum V6Replies: 1Last Post: 10-11-2006, 12:49 PM -
Replacing Turn signal bulb
By LA Girl99 in forum General HelpReplies: 10Last Post: 08-12-2005, 08:02 AM
