06-27-2007, 11:16 AM #1
can't find the bleeder please help
I can't find the damn bleeder for the slave. I have read that if you reach up directly from the line going into the trans it supposed to be right there but I didn't find it like that. I've been trying everything and I still haven't got anywhere. Can someone please help?
06-27-2007, 11:21 AM #2
it's right above where the line goes in. It's extremely hard to get to. I used a 1/4 ratchet with a deep 7/16 socket to get to mine. I think the best way would be to drill a hole on the inside of the car on the trans tunnel. I've seen this suggested before, you may try a search to find out info on that. I found that removing the drivers side o2 sensor helped to give me a little more space to work under there.
06-27-2007, 11:31 AM #3
I can get my hand past the unused tab that sticks up there I've been trying to feel and look but I can't see it or feel it. How close to the top of the trans is it?
06-27-2007, 11:39 AM #4
Its probably about halfway in between the line and the top of the trans. I feel your pain. It took me a while to find it too. I was convinced it wasn't there. Just be sure you use a ratchet that locks the socket onto it, so it doesn't fall into the bell housing. I couldn't really get my hand in there either, just had to figure out how to stick the ratchet up there just right to get it on the bleeder. It was a ROYAL pain. Stupid design, it's almost impossible to get to. I really think next time I'm going to pull my carpet back, and drill a hole in the floor pan to get to it.
06-27-2007, 11:51 AM #5
Yeah I was about convinced it wasn't there myself. I guess I'll keep trying, its just frustrating. I've been working on this thing all day and haven't got anywhere with it. Thanks for your help man.
06-27-2007, 01:42 PM #6
Well I still haven't found it.
06-27-2007, 01:45 PM #7
have you looked for any articles on cutting a hole in the floor pan? you could always do that and then reattatch the piece you cut out with screws when you are done. Sort of like making a removable panel. I'll look to see if I can find any articles on it.
06-27-2007, 01:48 PM #8
Here you go
http://www.ls1.com/forums/showthread.php?t=20520
need to know where the bleeder for the clutch is
By Big D Squared in forum General HelpReplies: 4Last Post: 07-17-2012, 01:29 PM -
no bleeder screw
By ssweet99ss in forum Manual TransmissionReplies: 4Last Post: 08-05-2008, 06:38 AM -
Remote bleeder for clutch
By black2002ws6 in forum Parts For Sale / TradeReplies: 7Last Post: 04-08-2007, 05:01 PM -
What's a Miti vac clutch bleeder, and where...
By Gnobility in forum Manual TransmissionReplies: 5Last Post: 01-07-2007, 08:14 PM -
I don't see no bleeder valve
By ANUTT1 in forum Manual TransmissionReplies: 5Last Post: 07-20-2006, 06:02 AM
