    Tampa, Fl.
    2002 WS6
    Remote bleeder for clutch
    I am making remote bleeders for the clutch. With this bleeder you can run it up to the engine compartment or out under the car to bleed the clutch. It also has a speed bleeder on the end so it's a one man operation to bleed the clutch. I am only getting top of the line parts to make them. One of the problems with making them is getting the fitting for the slave cylinder that will seal and not leak since it's not a machined surface. I have found what they call a bonded washer that will seal under high pressure to use on the fitting. I also have found a sealant to use on the threads that will not break down from the brake fluid. This provides a double seal for the fitting. I will be selling them for $75 with Free Shipping. Here's some pictures of it installed.
    georgia
    1 (100%)
    1998 pontiac trans am
    so this stays mounted all the time?
    Tampa, Fl.
    2002 WS6
    Yea it does. You just put the line up out of the way when you don't need it.
    !Ram Air Baffles, MTI smoke lid, Thunder Racing MAF ends, SLP smooth bellows, MAFT, Custom Tuning by LPP, !CAGS, Last of the Breed badges, LPP headers and Tru-duals. Hurst Billet Plus Shifter.
    georgia
    1 (100%)
    i guess i'll need one when i get to that part of putting my car back together when im done with my rebuild. PM me mailing info and when i get close to that point i'll send ya the money
    San Bruno
    -1 (0%)
    Blac & silver
    2000 ss camaro
    will this prevent my camaros clutch pedel from sticking to the floor after getting on it on the freeway. It takes like 30 secs plus to have it come back top normal hight.THANX
    georgia
    1 (100%)
    Quote Originally Posted by chad2000ss View Post
    when my clutch pedel was weak, my slave cylinder was bad. have to take tranny off to get to it. might not be your prob though
    San Bruno
    -1 (0%)
    Blac & silver
    2000 ss camaro
    Quote Originally Posted by rbrtlux View Post
    Thanx for the info. It only happens when i get on it on the freeway.
    georgia
    1 (100%)
    you need to post your problem under the proper forum. you will get more replys to possibles problems and fixes.
  1. need to know where the bleeder for the clutch is
    By Big D Squared in forum General Help
    Last Post: 07-17-2012, 01:29 PM
  2. tick performance remote speed bleeder line
    By turyg ls1 in forum Manual Transmission
    Last Post: 02-20-2011, 10:49 PM
  3. clutch alignment install tool and speed remote bleeder
    By disc0monkey in forum Parts Wanted / Trade
    Last Post: 11-05-2010, 01:58 PM
  4. no bleeder screw
    By ssweet99ss in forum Manual Transmission
    Last Post: 08-05-2008, 06:38 AM
  5. What's a Miti vac clutch bleeder, and where...
    By Gnobility in forum Manual Transmission
    Last Post: 01-07-2007, 08:14 PM
