Results 1 to 16 of 16
    mach111
    calif
    dwd
    wdwd
    HELP,tuner says you cant raise shift points
    Hi, Ive got a 00 a4 corvette with hollowed cats, ls6 intake ,02 zo6 cam., and 3.42 gears. My tunner at the chevy dealer dyno tuned my car without me there and it put out 319RWHP.
    It still idles kind of rough but the thing that gets me is he says you can't or don't raise the shift points on my zo6 cam install! He says you can't accuratelly set shift point due to the highdrolics shifting qualities and it's best to leave them alone? Is this true? Any feedback would be appreciated. Thanks!
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    Thats a new one for me. I change my shift points to what ever I want.
    Forged 383 | ATI D-1SC
    NX MAF Kit | 222/226 .585 115
    AS Stage II 6.0L FI Heads
    .....had a big reply typed out and changed my mind. If you're not happy with your tune/tuner I would search around for someone else and get a few references before going to see him. I think pretty much everyone with an auto moves their shift points up at least a little bit.
    Senior Member bills98ta's Avatar
    Feb 2007
    St Thomas, PA
    At least get a hand programmer to adjust them your self.
    Member 408WS6's Avatar
    Houston
    Current best: 10.60/126.8
    1998 Pontiac TA WS6
    Quote Originally Posted by mach350z View Post
    I would run for the hills if my tuner told me that
    mach111
    calif
    dwd
    wdwd
    Thanks, Do you guys think a raising the shift points would bennefit on my car with baisically just a 02 ls6 cam and intake from the stock shift points?
    Thanks I really appreciate the input!
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    stock for most LS1 cars is 5900 rpms. bringing it to 6100-6200 rpms is a good help.
    calif.
    What kind of tuning programmer does he have ?? Most all handhelds and some full tuners don't address the 2 commands involved it programming a shift pont---shift at RPM and shift at vehicle speed---Hydraulic shifting qualities ?? have no idea what he means by that--other than some tuners go crazy on base line pressures--that table gradualy increases line pressurre with engine torque---with a max setting of 96 PSI---usually achieved near WOT--If you add too much you'll get horrible shifts because full pressure will be achieved way before WOT----I've tuned about 200 automatic vehcles and adjusted the shift points on all of them---even on non-performance type tunes to get better fuel mileage ,towing ability & tranny life--it helps get rid of the "hunting for gears" and engine "lugging" and the pinging associated with those issues
    LSX Tuner edgz06's Avatar
    New Haven, Connecticut
    Yellow
    2004 GTO
    02 Z06 cam pulls much higher than stock and that's where you will make more power and lower e.t.s
    You need to take advantage of the better breathing past 5900 rpms that the cam and intake will give you.
    I would set it to shift at 6200-6400 rpms for the 1-2 and 2-3 shifts.
    Also, you could set quicker shift speeds, higher pressure and torque management delete.
    HP is all in the tune.
    Good Luck!
    04 GTO A4 6.6 liter,AFR 225,STS 76mm Turbo,96# Injectors,Innovate XD-16,Methanol,HPTuners,Custom Fuel,etc.
    Best E.T. 10.66 @ 130 mph http://www.mongillomotors.com/1066vid.html
    LSX Tuning with Mustang MD-1100 Eddy Current Dyno & HPTuners in the New Haven, CT. area
    I would look for a new tuner for a few reasons. I don't want you to think I am being disrespectful to you, but those HP #s are what I would consider very low for your mods and I would suspect its due to your tuner.
    Painted manta stripe
    Washington Pa
    2002 WS6
    Its time for a new tuner or buy hp tuners and start learning how to do it yourself
    calif.
    I don't think 319 RWHP is low---basically with only 2 mods--Z06 cam an LS6 intake--especially with an A4 drivetrain loss is approx 22% so that puts you at
    389 flywheel HP ---Stock being 350 that's a a 39 HP increase--sounds about right for that cam and manifold change-----Stock Z06 has 405 flywheel HP and that extra 16 HP is achieved with the addition of the 243 heads
    Senior Member camarojunky74's Avatar
    corona ca
    white, white and pewter
    Rip99SSA4,74Z28M4,02SSM6
    Quote Originally Posted by tblu92 View Post
    i would have thought more too! my buddys stock 02 z did 331 to the wheels. bone stock or a flowmaster muffler! that doesnt count thous
    my 99 ss with 135000 miles did 318 bone stock.
    i dunno, this was in rancho cucamonga ca, fairly close to sea level!
    corona ca
    both autos! oh i forgot i put a slp lid on on the 3rd pull but no gain was made
    Yellow
    2004 GTO
    Quote Originally Posted by camarojunky74 View Post
    Whether your at sea level or not, doesn't really matter with weather correction (SAE corrected). What makes more of a difference is the difference from one dyno to the next, especially if one dyno is an inertia wheel dynoe (Dynojet) and the other is a load style (Mustang) dyno.
    Type of tranny is also a big factor.
    corona ca
    it was a dyno jet
  1. Shift points?
    By Mystic Z-28 in forum Internal Engine
    Last Post: 03-05-2011, 03:56 AM
  2. shift points?
    By clg82 in forum Automatic Transmission
    Last Post: 05-13-2007, 04:04 PM
  3. 323's to 373's shift points
    By Andy Lappin in forum Computer & Tuning
    Last Post: 06-19-2006, 12:36 PM
  4. What Shift Points Should I Use
    By MATTTRANS2000 in forum Drag Racing
    Last Post: 03-23-2006, 12:35 PM
  5. Shift points help.....
    By redz284u in forum General Help
    Last Post: 09-21-2005, 03:11 PM
