    MATTTRANS2000
    Guest
    What Shift Points Should I Use
    I Have A Bone Stock 2000 Trans Am 6 Sp What Rpm's Should I Shift At?
    The Best Iv Done At The Track Is A 13.76
    Thanks Matt
    Tulsa,OK
    Quick Silver
    2002 Z06
    When I took my 98 formula to the Dyno bone stock it peaked at 5500. When I ran to 6000 it just dropped. I recommend 5500 until you do something to it to make it make power past 5500. Best way to know for sure is to go to the dyno and check it out. Rev limiter is going to stop you at 6000-6200 anyways.
    Near St. Louis
    1998 T/A
    Shifting around 6 will put the next gear into more power. 5500 is slightly too early.
    Tech Junkie hammertime's Avatar
    Belleville, IL
    Pewter Metallic
    Quote Originally Posted by 98eles1
    What he said. It's not like you hit a brick wall at 5500 rpm. Power does start to taper off, but there is more power available in the next gear if you shift it near or at the redline.
  1. Shift points?
    By Mystic Z-28 in forum Internal Engine
    Last Post: 03-05-2011, 03:56 AM
  2. shift points
    By *JC* in forum Automatic Transmission
    Last Post: 09-01-2009, 04:11 AM
  3. new shift points
    By ssmike in forum Automatic Transmission
    Last Post: 07-25-2008, 11:04 AM
  4. Shift Points on A4
    By FantaZGuy28 in forum Drivetrain
    Last Post: 11-05-2006, 12:54 PM
  5. 323's to 373's shift points
    By Andy Lappin in forum Computer & Tuning
    Last Post: 06-19-2006, 12:36 PM
