Results 1 to 20 of 37
Thread: Widest Tires Possible?
06-20-2007, 08:59 PM #1
So it is time for new tires on my 1998 T/A I have 275/40/17 on my stock set of WS6 5 spoke rims. Does anyone know what the widest tire I can put on the 17 rims without having any clearance issues. I know they make a 285/40/17 and a 315/35/17 they will fit the rim but i'm not sure of any rubbing issues. Does anyone have anything wider than a 275/40/17 on the rear of there T/A?
06-21-2007, 06:26 AM #2
I have 315/35-17 on a 11" rims.
The largest tires that the manufacturer allows for your rims is 275/40-17.
Here is a picture of 315/35-17 om all four corners:
06-21-2007, 06:36 AM #3
Kumho Ecsta 275's
DS-G3 315's
I have a write up on making the 315's fit on ls1tech but here's the cliff's notes:
-Moderate hammering of wheelwell
-Shaved bumpstop with 5" Angle Grinder
-Used rubberized undercoating
Some ppl have no rubbing issues but I did this as a safety precation to keep them from rubbing on highspeed turns. I also recommend an adjustable panhard bar. If you are lowered, expect more issues.
Edit: For the 315's I would recommend at least an 11" wide wheel. Some would go smaller but I personally don't recommend it.Last edited by blackwidow99; 06-21-2007 at 07:54 AM.
06-21-2007, 06:37 AM #4
my friend had 325/35/17s on the rear of his z. no problems so far. they are pretty friggin wide though as they are the e.t. streets.
good luck. and nice car SOW!
06-21-2007, 07:06 AM #5
You should repost your write-up here as this question is asked (almost) daily. You need to (or not need to) hammer based on what kind of tires you have on the rim. Some are far 'thinner' than others.
Thanks bro, I have been pushing it hard on the track this year.
06-21-2007, 07:09 AM #6
06-21-2007, 07:36 AM #7
Here's the link...
http://www.ls1.com/forums/showthread.php?t=54618
06-21-2007, 10:06 AM #8
How much metal did you take off of the bump stop. I saw your picture and it looks like you can only take off just alittle before you hit the rubber?
06-21-2007, 10:51 AM #9
06-21-2007, 11:24 AM #10
I did that too. ^^
But know I run different tire which sit at 12.75" on the rim and actually had to trim off more.
You want to shave off enough so that the rims/tires clear when the rear end is in full droop.
06-21-2007, 12:44 PM #11
I have 315/35 17 Nitto DR with no problems at all..the tire has a slight roll over but other than that they work great. If you go BFG DR's they will rub the inner fender well.
06-21-2007, 01:00 PM #12
06-21-2007, 01:01 PM #13
06-21-2007, 03:02 PM #14
Hey blackwidow99 what size tires you got on the front of your camaro?
06-21-2007, 06:03 PM #15
06-23-2007, 01:34 PM #16
Has anyone ran Sumitomo HTR Z tires on there car? The Tirerack.com has 315/35/17 on sale for $96.00. Thats super cheap. Just woundering if they are a decent tire for the money or if they are total garbage?
06-23-2007, 02:37 PM #17
Hey Supercharged666 I just bought sumitimo 275's and absolutely love them. I hear they wear fast but for dry traction they are the best bang for your buck. I has Nitto 555's on before and think these HTRz's are twice the tire for traction. Don't think you are getting a cheap tire at all
06-24-2007, 07:06 AM #18Member
- Jun 2007
- loyall ky
black, and black- 04 M6
tires
i got Sumitomo HTR Z a few weeks ago on my gto they seem to be good tires good traction dont knwo about wear yet but i like them so far
06-24-2007, 04:27 PM #19
Just went to the trasck today and turned in a best 1.92 60 foot with my sumitimo's compared to the best 2.2 with my 555 nitto's Really great tires I can't say enough for the price
1998 Z-28 LT Headers & Cat Delete Off Road Pipe, 160 t-stat, Hypertech, all the free mods, Sumitimo HTRz11 tires, B&M Ripper, 150 shot of the funny stuff, Spec 3 clutch, 3.73 gear, SS Hood.
Best E.T. W/O N2o 12.9
06-27-2007, 07:31 AM #20
Alright i'm sold, I just order the HTR tires from the Tirerack.com i got 275 for the front and 315 for the rear. I plan on doing the rear wheel base mod for clearances issues. I know that some people said that they had no problems with there tires but i'm gunna go ahead and do it anyway.
Widest rear tires and best price?
By stolenthunder in forum Wheels and TiresReplies: 1Last Post: 11-27-2010, 08:42 AM -
Question: widest tires for TT M 17X9 45 OFFSET?
By LetemSpin1 in forum Wheels and TiresReplies: 8Last Post: 07-25-2010, 05:27 PM -
what is the widest tires i can put on a 02 camaro
By LS2 Camaro in forum Texas MembersReplies: 2Last Post: 04-27-2009, 07:54 PM -
wIDEST tires on a stock camaro?
By Frankthetank in forum Wheels and TiresReplies: 8Last Post: 11-02-2007, 06:10 PM -
Widest tires on 2002 Z28?
By Rich L in forum Wheels and TiresReplies: 7Last Post: 08-07-2006, 07:52 AM
