    Member Rich L's Avatar
    near Atco NJ
    Burgandy
    2002 Z28
    Widest tires on 2002 Z28?
    Could any one tell me the widest tires my 2002 Z28 can fit?
    Im looking to upgrade to get better traction...
    I currently have Good Year Eagle's RS-A
    P245/50 R16's.
    IL
    2002 Pontiac Trans Am
    i have 275/40ZR18's out back and 245/45ZR17's up front and that is about a 1/4" clearance in the back it your want any wider you will more than likely have to go with a different offset or a spacer.
    Aug 2000
    Indy
    You mean widest tires on stock rims ?
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    i have 17x11 w/ 315/35-17 on all corners.
    some have 17x12 on all 4 w/ 335s... but that needs some flaring in the back.
    Eugenio_SS
    near Atco NJ
    Burgandy
    2002 Z28
    Quote Originally Posted by Danger731 View Post
    yes. or at least I believe they are stock... 16's
    My car has no "traction control" so I wanna put wider tires on...
    any help is appreciated as far as best size and type of tire for the street.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    just swithcing to drag radials will make all the difference.
    Member ProwlerZ's Avatar
    Myrtle Beach
    2002 Z28
    I believe stock 16s will only hold 255s safely, though people always push it. If you want wider, you need wider wheels to hold them. I'd suggest 10.5 wide 17s for the back, 9 wide 17s for the front, then you can run between a 275-305 out back, and stick right around a 245-255 in front.
    She's baaaaaccccck...
    '02 Z/28 M6 Hardtop
    Member jmhvenom's Avatar
    Cincinnati, OH
    2002 Z28
    Get 17 in rims x 9.5 i think, and you can get 275s with no problem... pretty good, but i have seen people that put 315s on them. 11inch wide in the back with 315s works good for most people.
  1. Widest rear tires and best price?
    By stolenthunder in forum Wheels and Tires
    Last Post: 11-27-2010, 08:42 AM
  2. Question: widest tires for TT M 17X9 45 OFFSET?
    By LetemSpin1 in forum Wheels and Tires
    Last Post: 07-25-2010, 05:27 PM
  3. what is the widest tires i can put on a 02 camaro
    By LS2 Camaro in forum Texas Members
    Last Post: 04-27-2009, 07:54 PM
  4. Widest Tires Possible?
    By supercharged666 in forum Wheels and Tires
    Last Post: 05-22-2008, 09:29 PM
  5. wIDEST tires on a stock camaro?
    By Frankthetank in forum Wheels and Tires
    Last Post: 11-02-2007, 06:10 PM
