Results 1 to 20 of 23
Thread: Loss of power help
06-09-2007, 01:25 AM #1
Loss of power help
Hey every one had a question i recently ran my car in noticted a big jump in my ET
from a 13.5 in 100 deg.. to 14.0 in 80deg
the 13.5 was with slp loud mouths descreend maf only
the 14.0 was 2 weeks later 20 deg cooler mti lid free ramiar
smooth bellow so i took my car to mti in they said they dont see any thing wrong except for a tranny mount
any one have any idea why i lost .5 secs off my ET
could it be the trannymount?
thanks any advise would be apreciated
06-09-2007, 07:01 AM #2Member
- Jun 2006
- USA
- 2001 WS6, 2003 SRT4(sold)
Post your slips... the times could help troubleshoot.
06-09-2007, 07:11 AM #3
where you gripping right off the line... maybe you just spun a bit
06-09-2007, 07:51 AM #4member since may 2000
- Dec 2002
- n/w chicago
bad air and bad launch can kill times alot.
never expect exact times from day to day.
the maf maybe pulling timing2000 nhra edition formula
a few bolt ons, 379 rwhp
11.96 @113.25
06-09-2007, 04:20 PM #5
i lost the time slips but my 60ft was 2.1 on the 14.0
in 2.2 on the 13.5 trap speed was like 98on the 14.0
102 on 13.5 forgot my 1/8 but i think it was like 13.5 8.7...14.0 9.2 i think.also i had replaced the tensioner pulley in ideler pulley oreilys orderd the wrong idler in the mechanic told me he could make it fit it wasent to much bigger but it had more width in he removed some washers in shoved it on but the belt also had some slack in it was rubbing so the day after i went to the track i had mti remove that pulley in belt but it dont feel like it helped
thats when they told me about the tranny mount btw it was because of the a/c i changed those pulleys
06-09-2007, 04:28 PM #6Member
- Jan 2006
- Houston
Current best: 10.60/126.8- 1998 Pontiac TA WS6
Are you throwing any codes? If so which ones? You might pull your plugs out and check them. Also check your O2 sensors. When those go bad, the car runs like doo..
06-09-2007, 05:41 PM #7
it seems to be running fine ive replaced my wires last week
ac delco plugs like 1k-2k miles ago the wires are msd from mti they say 02 sensor make it idle rough my car dosent idle rough
06-09-2007, 06:19 PM #8Member
- Jan 2006
- Houston
Could be just poor track conditions when you ran last..
06-09-2007, 11:07 PM #9
no because my cousin was with me both times in he ran a 13.0 when i ran the 13.5 in 12.8 when i ran the 14.0
06-10-2007, 08:56 AM #10
06-10-2007, 09:50 AM #11
If your trans mount is bad you are not going to get all the power tranferred to the rear wheels because the back of the tranny will be jumping up and down and so will the torque arm. Replace the mount and run it again.
06-10-2007, 12:00 PM #12
06-10-2007, 12:07 PM #13
06-11-2007, 12:30 AM #14
06-11-2007, 08:57 AM #15
BS it is... you must really not know how to drive then
06-11-2007, 09:23 AM #16
06-11-2007, 09:47 AM #17
I run the same thing (mine a4 too)... I shift it through all the gears to get it perfect every time... but my 60ft is unusually good 1.6sec
06-11-2007, 11:07 AM #18
wow
06-12-2007, 10:15 AM #19
any one else think its the tranny mount if so witch one do i git? thanks
06-14-2007, 10:17 PM #20
Bump can the tranny mount cause the jump in E:T
Help: Power loss
By davidz28 in forum Camaro / SSReplies: 3Last Post: 09-11-2010, 08:00 AM -
How much power loss ?
By karpetcm in forum Computer & TuningReplies: 2Last Post: 03-22-2010, 01:22 PM -
Loss of power
By 99RTA in forum General HelpReplies: 0Last Post: 05-19-2009, 05:52 AM -
Help: Power loss
By BIG GUNS in forum Internal EngineReplies: 1Last Post: 10-20-2008, 12:44 PM -
is this why i have power loss???
By 02sscamaro in forum General HelpReplies: 1Last Post: 09-13-2007, 01:15 PM
