Results 1 to 3 of 3
Thread: How much power loss ?
03-22-2010, 01:26 PM #1
Well, i wanted to know how much power do you lose from pulling 2 degrees of timing so i can run nitrous safely. I can use what Frost has send me which allows the computer to only pull timing once i activate the switch on my nitrous but for my curiousity id like to know either way is there a significant power loss from pulling 2 degrees of timing.
1993 Z28 M6: K&N Intake, 52mm TB, TB Bypass, No Cats, Exhaust Cutout, Flowmaster Muffler, 3.90 Gears, 160 Thermo, Tune, BMR Springs, Bilstein Shocks, 3 Point SFC,s & MGW Shifter.
03-22-2010, 02:12 PM #2
Hey Mike,
That's not a question with a solid answer; there are more variables than you would be able to provide...
With that said, I'd expect 5-9 rwhp depending on the combo, how close the timing was to optimal to begin with, etc.
03-22-2010, 02:22 PM #3
Thanks Frost i was actually going to start the post by saying a message to FROST. I think once i install my headers im gonna send my computer back out to you to get it tuned for LT's, ORY and the tune for a 150 shot. I still have that thing you gave me to activate the tune for nitrous only when the nitrous system is activated and when im N/A it will not pull timing. The only problem i had with the that tune is even though i didnt install the LT's but was running the tune for LT's it seemed like i was hitting the rev limiter early in 1st and 2nd gears only. I think maybe because our cars tend to run rich after LT's install maybe some fuel was pulled in the top end and when i installed the computer without installing the LT's it was running too lean, maybe not sure. I need to get back to work and start making money been out for a couple of months, im lucky i work at a dealer and they give good pricing when it comes to labor.
Help: Power loss
By davidz28 in forum Camaro / SSReplies: 3Last Post: 09-11-2010, 09:00 AM -
Loss of power
By 99RTA in forum General HelpReplies: 0Last Post: 05-19-2009, 06:52 AM -
Help: Power loss
By BIG GUNS in forum Internal EngineReplies: 1Last Post: 10-20-2008, 01:44 PM -
is this why i have power loss???
By 02sscamaro in forum General HelpReplies: 1Last Post: 09-13-2007, 02:15 PM -
Power loss
By Even10Flow in forum ConvertibleReplies: 5Last Post: 05-16-2007, 08:26 AM
