Results 1 to 11 of 11
    Bomb Technician Krazy351w's Avatar
    In A Jesus Christ pose.... on the banks of the Thames with Ratty and Mole.
    hunter Green
    92 Camaro RS 350 Special
    any easy way to tell 350 from 305
    i got a guy trying to sell me an engine saying its a 350 but my friend tells me that its a 305 and a waist of money.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    casting number on the back of the block behind the driver's head on the bellhousing mount pad. then, go to www.mortec.com and look it up.
    Junior Member smallblockhero's Avatar
    Buffalo N.Y.
    dark blue
    1998 Z28 A4
    by lookin at it?..um no not really. unless you know casting numbers. is it out of the car? GEN I's all are externaly the same dimensions and share parts so its hard if you dont know what to look for.
    hunter Green
    its not in anything. the guy said it came from either the 80 model vette or mabey a truck and that its a 350tbi but my friend said its a 305 cuz the valve cover bolts go down the center.
    orlando, fl
    2014 camaro 2ss/rs
    Quote Originally Posted by Krazy351w View Post
    they do on 350 motors as well. called centerbolt valve covers. started around 1985.
    hunter Green
    thats what i thought because my 92 rs has a 350 in it and its like that and im almost positive its a 350 because it runs a 13.6 E.T. and all i have done to it is regear. i Know a 305 wont run that well.
    orlando, fl
    2014 camaro 2ss/rs
    well that wouldn't be a factory 350 in the RS as they only came with 305 TBI from the factory. someone swapped the motor out. a 305 can run that well. just takes some really good work.
    hunter Green
    o i knew it wasnt a factory engine. liek i said im just really sure its a 350 due to how well it runs, considering its bone stock. any ways ill look up the casting numbers and hope its a 350. also i will be rebuilding my engine in the RS soon. what all should i have done to it to hop it up some. id like to get at least 350hp
    Rollo Tomassee AKIRA's Avatar
    Outside the box
    I was going to say the exact same thing on both counts.
    orlando, fl
    2014 camaro 2ss/rs
    well, technically the RS could come with a 350 TPI. it was the B4C police package. rare car, if it is one.
    hunter Green
    no its not a tpi its tbi
  1. Go easy on me please
    By z-maro in forum Manual Transmission
    Last Post: 06-17-2011, 11:04 AM
  2. Help: Easy way to do this?
    By 01NavyBlueSLPSS in forum Camaro / SS
    Last Post: 06-13-2011, 05:41 PM
  3. 190 and off easy
    By specialized.1 in forum Kill Stories
    Last Post: 01-14-2008, 12:01 PM
  4. Looking For EASY 12's...
    By N20LT4 in forum External Engine
    Last Post: 06-24-2007, 06:09 PM
  5. How can I get easy HP for less!
    By GreenBirdman in forum Firebird / WS6
    Last Post: 02-18-2007, 04:07 PM
