Results 1 to 16 of 16
    Rice killa 01NavyBlueSLPSS's Avatar
    Dec 2010
    Washington
    01 Camaro SS M6
    Easy way to do this?
    I was replacing my front turn signal housing yesterday and after getting everything loose they were a huge pita to maneuver out. I literally had to pry up bending the plastic bumper almost breaking the housings. I did have my headlights off as well. Well while getting the new ones in(which was even more of a pita) I think I separated the lens on the end. There is condensation inside my left sig. So I need to get them back off. Is there a better way to get them out without completely removing the bumper? Thanks
    Member tpilews's Avatar
    Tampa, FL
    '98 Z28
    Don't they just slide out the front?
    Dec 2010
    Washington
    01 Camaro SS M6
    Quote Originally Posted by tpilews View Post
    No the lights are about an inch taller than the opening
    Oct 2009
    pasadena md
    Blog Entries
    2
    2002 SS Camaro
    take it out from the bottom that is how I did them a while back
    Dec 2010
    Washington
    01 Camaro SS M6
    I got them through the top, my question is regaurding maneuvering the lens out of that little cubby hole it sits in. It seems physically impossible without stretching the bumper to get it out or completely removing the bumper
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    I think you could take the inner fender liner out,two 8mm or 10mm (sorry,cannot remember which) from in front of the front tire,and the lamp housing should be easily accessible.noticed this when i removed the air pump and secondary air injection system.
    Posted via Mobile Device
    Orlando, FL
    Mean Black
    Quote Originally Posted by 02transamce View Post
    yup, If you look from underneath the front bumper there is two 10 mm bolts on each side of the bumper. Remove those and you can open a section of the plastic cover that grants access to the turn signal bulbs.
    Mustang Eater Ls_won's Avatar
    Feb 2010
    Springfield, Missouri, United
    Maroon
    2000 z28 6 speed
    If you take your headlights out, and then loosen the one bolt that holds on to the bumper they slide right out through the top
    2001 B4C Totaled 4/25/11
    2000 Z28 M6 Cammed N' Slammed (SVT KLR)
    Dec 2010
    Washington
    01 Camaro SS M6
    Quote Originally Posted by Ls_won View Post
    I did take the headlights out, loosened the three bolts that hold the light to the bumper. It didn't just slide out tho. There were obstacles blocking each end preventing it from coming out
    Feb 2010
    Maroon
    2000 z28 6 speed
    it worked for me man.. hmm idk i guess try taking off the plasics underneath and dropping them through the bottom, alot of bolts but its not going to scratch anything up.
    Senior Member 98maro's Avatar
    Feb 2010
    north bay california
    00 camaro ss M6 #6695
    I removed the headlight. It Took me about 25 min to figured out how to remove the head light! But once it was out took me less than 5 min to remove the sidemarkers
    It came out from the top whee the headlight is.
    You don't have to get the bumper lose
    02 tahoe Z71 blacked out
    98 z28 red m6 sold
    07 zx6r ninja flat/black sold
    08 zx6r ninja sold
    Nov 2009
    North Carolina
    2001 Camaro Z28
    Quote Originally Posted by 01NavyBlueSLPSS View Post
    Im not sure whats up with these sidemarkers i had the same problem as you i had to pry the thing out of the little slot. I also took out headlights. Im wondering if some cars got a slightly different style side marker housing or something.
    Dec 2010
    Washington
    01 Camaro SS M6
    Quote Originally Posted by davidz28 View Post
    Finally someone knows what I'm talking about. It's like the sidemarkers are too wide for the space the are in. The only way to do it without prying would be to remove the bumper it seems. What a PITA
    Nov 2009
    North Carolina
    2001 Camaro Z28
    I had to pry mine out but the i took a dremel to them so they would go back in easier. My car is also a 2001 i wonder if its only a certain year model that has the problem.
    Dec 2010
    Washington
    01 Camaro SS M6
    Damn wish I had thought of that^
    Feb 2010
    Maroon
    2000 z28 6 speed
    yes i also meant removing the headlight, removing the bolts on the side of the bumper to give it some wiggle room, then you are good to go!
  1. Go easy on me please
    By z-maro in forum Manual Transmission
    Last Post: 06-17-2011, 11:04 AM
  2. 190 and off easy
    By specialized.1 in forum Kill Stories
    Last Post: 01-14-2008, 12:01 PM
  3. Looking For EASY 12's...
    By N20LT4 in forum External Engine
    Last Post: 06-24-2007, 06:09 PM
  4. any easy way to tell 350 from 305
    By Krazy351w in forum General Help
    Last Post: 06-08-2007, 05:49 PM
  5. How can I get easy HP for less!
    By GreenBirdman in forum Firebird / WS6
    Last Post: 02-18-2007, 04:07 PM
