06-06-2007, 09:34 AM #1
How Much Can An Ls1 Block Handle?
I Am Looking To Beef Up My Ls1, How Much Horsepower Can The Block Take?
1998 Trans Am Vert, M6, Soon to be full of goodies......
06-06-2007, 09:54 AM #2King 0f n00bz
- Jan 2006
- Shepherd, Michigan
the block can take some serious abuse ups of 1000+ internals are a different story..but if you beef up the internals and ect...but heat is the big problem that would cause the ls1 block's demise
06-07-2007, 02:15 AM #3
A stock bottom-end will take 600rwhp no problem. The block and crank can take upwards of 900rwhp. The pistons and especially the ring-lands are the weakest link. Bear in mind that those numbers can change with high cylinder-pressures (nitrous) and high-rpm.
06-07-2007, 06:16 AM #4
I am looking to do a complete over hall with forged internals and then some serious boost what would be the best kit to do this with? (internals)
06-07-2007, 08:31 AM #5
I read an article some time back of a guy who bought a 98 TA with 120,000 miles on it. threw a turbo on it and tried to blow the motor so he could throw in a brand new motor setup that he had built. The only thing internally he changed was the rockers. over 140 quarter mile passes and 14,000 miles later boosting between 12-15 PSI. He finally just gave up and did the motor swap cause he couldn't blow up that stock LS1 block...LOL. He was running low 10s, high 9s every pass.
So I am guessing it takes A LOT. or just some really bad luck. And with forged internals, hmmm give her all you can.
06-07-2007, 11:44 AM #6
What Would Be A Good Set Up Internally For A Nasty Turbo? What Is The Best Displacement If I Am Going To Be Gutting Out The Block?
06-07-2007, 11:37 PM #7
06-08-2007, 06:30 AM #8
What$ Do You Think I Could Do The 347 For?
06-11-2007, 03:14 AM #9
Check with the sponsors, but you could probably work something out for a couple grand...
Chevy Small-Block, Big-Block & Transmission Buildi
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 11-20-2009, 01:50 PM -
how would you handle this?
By SMWS6TA in forum Almost Anything GoesReplies: 15Last Post: 08-25-2009, 09:01 AM -
How much power can stock LS1 block safely handle?
By svtben in forum Forced InductionReplies: 1Last Post: 03-29-2007, 02:00 PM -
whats the biggest head a stock LS1 block can handle
By cannotbeheldliable in forum Internal EngineReplies: 6Last Post: 05-01-2006, 08:25 PM -
How much power can an alluminum block handle on Boost
By JD_Z28 in forum Forced InductionReplies: 20Last Post: 04-16-2006, 04:58 PM
