    whats the biggest head a stock LS1 block can handle
    i was wondering what the biggest head a stock LS1 block can handle. is it 200cc or could i go any bigger?
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    you could get a 225 if you wanted.
    a few bolt ons, 379 rwhp
    11.96 @113.25
    Memphis
    96 Camaro
    205 Afr head is the biggest I would put on a stock motor.
    Respect Big G
    Awaiting Activation Liquifire's Avatar
    central wisconsin
    you CAN put a 225 on it but they recommend that if under 380 cubes to stick with the 205's ..........you can put bigger heads on it but if it doesn't translate to numbers then why do it? It would just be a waste of money...........
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    really need to think about the heads your buying. buying parts that the manufactur says adds HP is not the way to go. Application and depth of wallet have alot to do with it, not the biggest CC.
    i was looking to spend around 1000 dollars. how are the patriot heads. does the 205 cc head create more horsepower with the 346 block. which would be better for a turbo application the 205 or 225?
    central wisconsin
    Quote Originally Posted by cannotbeheldliable
    You wont find AFR's for around a thousand dollars..........most people will agree that the best bang for the buck heads are the Patriots. The size of the heads depend on the displacement..........if you have the stock block(346) then go with the 205's.........if it is stroked to a 383 or bigger go with the 225's.
  1. Whats the biggest POS car you ever owned?
    By 98formy in forum Almost Anything Goes
    Last Post: 03-23-2011, 06:03 AM
  2. How Much Can An Ls1 Block Handle?
    By schrysler in forum Internal Engine
    Last Post: 06-11-2007, 03:14 AM
  3. How much power can stock LS1 block safely handle?
    By svtben in forum Forced Induction
    Last Post: 03-29-2007, 02:00 PM
  4. How much power can an alluminum block handle on Boost
    By JD_Z28 in forum Forced Induction
    Last Post: 04-16-2006, 04:58 PM
  5. whats the biggest tire
    By lt11le in forum GTO
    Last Post: 11-24-2005, 05:34 PM
