Results 1 to 10 of 10
05-24-2007, 07:38 PM #1Junior Member
- Jul 2006
- Florida
- iTrader
- 1 (100%)
White- 2001 Camaro Z-28
MSD WIndow Switch, TB, MAF, Purge Lines
I have an ASP pulley for 98-02 Camaro/Firebird LS1 with 2 brand new belts for an easy and instant install. The pulley brand new is $224.00, the belts are about $55. This includes a new serpentine, and a new A/C belt. The pulley has been installed but the belts are new! I will take $190 shipped for everything.
I have a used MSD Window Switch P/N 8956 with a 3000 pill included. This switch has the quick connects already wired in for a wet nitrous kit. It was purchased when I bought my TNT kit. It is $97.00 new from MSD. I will take $40 shipped for it including all the wires and the 3000 rpm pill. -Sold
I have a stock Throttle Body from a 2001 Camaro Z28 with LS1, no sensors are included. The car has 58,400 miles on it. The throttle body worked when it was removed and is guaranteed. I will take $75 shipped. -SOLD
I have a stock MAF from the same car listed above. It has never been ported or polished. It has however been descreened. The MAF worked fine when it was removed. I will take $75 shipped.
I also have some misc. items.....power ring for a TNT Nitrous kit. This is a RUBBER POWER RING, not the stainless ring. This ring was used because a larger throttle body was being used. It has the holes pre-drilled for the dual nozzle setup. It is a larger bore ring and will still work with a stock TB but will require the larger clamps. I also have a set of purge lines that work with any purge solenoid. They mount on the solenoid and run along the top of the intake and then turn 90 degrees straight up through the cowl. This will complete a large purge and is mainly for show purposes. This will purge through 2 lines directly in front of the windshield and looks extremly aggressive when seen under blue LED or at night. I will take $35 shipped for both the power ring and the purge lines.
I accept PayPal only because it is safe for you and me. I will ship the following day after the payment is received. My PayPal email address is [email protected]. Thanks. -Tom.Last edited by tommyjt2006; 06-01-2007 at 07:56 AM. Reason: New Item added to list.
05-25-2007, 04:40 AM #2Junior Member
- Jul 2006
- Florida
- iTrader
- 1 (100%)
These items are located in Mobile, AL if anyone lives close by. Thanks. -Tom.
05-28-2007, 09:07 PM #3Junior Member
- Jul 2006
- Florida
- iTrader
- 1 (100%)
Anyone interested?
05-28-2007, 10:43 PM #4
ill take the MSD switch. PM sent
05-29-2007, 03:15 PM #5Junior Member
- Jul 2006
- Florida
- iTrader
- 1 (100%)
MSD Window Switch is sold to smallblockhero. Thanks.
06-01-2007, 07:52 AM #6Junior Member
- Jul 2006
- Florida
- iTrader
- 1 (100%)
Stock TB is sold. I also have an ASP Pulley with the belts necessary to mount on a 98-02 Camaro LS!. I will take $190 for all of it. This includes the ASP Pulley, main serpentine belt (Brand New), and the A/C Belt (Brand New). Thanks.
06-01-2007, 03:36 PM #7Junior Member
- Sep 2005
- South Alabama
- iTrader
- 0
Black- 2001 Z28 A4
How much picked up for the pulley and belts?
06-01-2007, 09:16 PM #8Junior Member
- Jul 2006
- Florida
- iTrader
- 1 (100%)
PM Sent. Thanks.
06-03-2007, 09:07 PM #9Junior Member
- Jul 2006
- Florida
- iTrader
- 1 (100%)
PM Sent on Pulley & belts. The ASP pulley and belts are still for sale. The TB has not been sold.
06-04-2007, 07:55 PM #10Junior Member
- Jul 2006
- Florida
- iTrader
- 1 (100%)
These items are now listed on eBay. Thanks guys.
Where to cut off purge lines?
By ls1camino in forum NitrousReplies: 12Last Post: 11-08-2009, 06:47 AM -
Purge Switch Connector?
By hutchb4 in forum NitrousReplies: 3Last Post: 11-09-2006, 08:23 PM -
NOS 5177 kit, purge, heater, window switch
By timpointzero in forum Parts For Sale / TradeReplies: 4Last Post: 01-24-2006, 04:27 AM -
NOS 5177 kit, purge, bottle warmer, & window switch
By timpointzero in forum Parts For Sale / TradeReplies: 2Last Post: 01-14-2006, 11:48 AM -
Purge and Window Switch
By greggy2belly in forum Parts Wanted / TradeReplies: 0Last Post: 09-30-2005, 07:13 PM
