Thread: Purge Switch Connector?
11-05-2006, 05:39 PM #1Junior Member
- Oct 2005
- DFW
Black- 99Z28
I am wiring my setup with a purge, went out and got a button but I can't find a push connector small enough to attach to the backside. Switch says terminals are 0.110" male blades. Anyone know of any resources or methods as to how you wire it up?
11-05-2006, 08:42 PM #2
all i do is crimp the ones i have to be tighter on the ends to make the connection. you can also solder the wire to the switch terminals.
11-07-2006, 11:43 PM #3Junior Member
- Oct 2005
- DFW
Black- 99Z28
Thanks for the info, my soldering skills need some work so I will just squeeze the larger connectors on. Cheers
11-09-2006, 08:23 PM #4
Go to your local RadioShack and they can get you the "micro" connectors.....
02 WS6 Evap Purge Solenoid Connector
By Dandur805 in forum Firebird / WS6Replies: 4Last Post: 04-09-2014, 09:37 AM -
MSD WIndow Switch, TB, MAF, Purge Lines
By tommyjt2006 in forum Parts For Sale / TradeReplies: 9Last Post: 06-04-2007, 07:55 PM -
NOS 5177 kit, purge, heater, window switch
By timpointzero in forum Parts For Sale / TradeReplies: 4Last Post: 01-24-2006, 04:27 AM -
NOS 5177 kit, purge, bottle warmer, & window switch
By timpointzero in forum Parts For Sale / TradeReplies: 2Last Post: 01-14-2006, 11:48 AM -
Purge and Window Switch
By greggy2belly in forum Parts Wanted / TradeReplies: 0Last Post: 09-30-2005, 07:13 PM
