Thread: Air Conditioner Conversion
05-22-2007, 05:07 PM #1Junior Member
- May 2007
- SALT LAKE CITY UT.
BLACK- 98TA
I Have A 94 Firebird With A Ls1/ws6 Conversion. I Want To Use My
Air Conditioner. (its Geting Hot).
The V6 Used An Expansion Valve Control & The Ls1 Uses The Orifice
Tube Style. Also, The Pcm's Control Differently. Has Anyone
Homologated The Two Systems Togeather? I Don't Want To Change
The Evaporator If I Can Get Away With It. Lil Help Please
05-23-2007, 04:36 AM #2
No I haven't done that myself. But I don't think you have as much of a problem as you think. You might have to have a few hoses custom made but that's not a big deal. The orifice type will operate without any outside control-no issues there. The evaporator will operate fine too. As for the PCM though I have no knowledge of the differences so I can't help there. Basically my understanding of that is it will kick the idle speed up when the compressor kicks in so as to not stall the motor. Maybe it really won't be much of an issue in this application- I'd give it a shot and see what happens. Now fan control- you might have to go to a manual control switch to turn your fan on when the A/C is on. These are available from a couple different sources.
05-23-2007, 09:32 AM #3Junior Member
- May 2007
BLACK- 98TA
02z28ls1-air Conditioning Question
Thanks For The Ac Answer:
I Had Forgotten About The Throtle Boost On The Ac.
I Will Charge The System And Try The Expansion Valve Evaporator.
Its A Lot Of Work To Swap Evaporators. I Understand The 98 Pump
Has A Pressure Regulator In It, Hope This Works On The Old System
Ok. Acording To The Schematic The 94 Used A Temp Control To Regulate The
Pcm And The 98 (orifice Type) Only Sends Presure Information To The Pcm. Ill Leave The Pressure Switch Hooked Up For Pump Protection And See If The Expansion Valve Will Control Ok Without
Icing The Evaporator.
Thank For Your Help 02z28ls1
Jw
05-23-2007, 09:35 AM #4Junior Member
- Oct 2006
- Mesquite, TX
Black- 2001 Z28 M6
The main difference between the orfice tube and expansion valve is that the compressor is cylced off when low side pressure drops to a certain pressure on the orifice tube configuration. The expansion valve runs the compressor continously. I know the LS1 PCM monitors the pressures through some transducers. It is set to cycle the compressor off at a certain point.
There is two ways you could go about getting it to work.
1. Wire in a relay to turn on the compressor and wire a manual fan control to turn on the fans when the HVAC control is set to A/C. The only down fall to this is that the engine idle speed won't increase when the a/c is turned on.
2. Wire the PCM into the HVAC controls and to the compressor clutch relay. Reprogram the PCM to keep the compressor on all the time with Hptuners or EFI live (I am not 100% sure this parameter exists in the program).
Help: 1999 WS6 Air Conditioner
By madcow in forum General HelpReplies: 16Last Post: 08-21-2012, 02:29 PM -
Air conditioner
By AfterYou in forum General HelpReplies: 8Last Post: 11-29-2010, 07:48 PM -
Air Conditioner
By x-lr8 in forum General HelpReplies: 1Last Post: 08-22-2010, 02:05 PM -
Air conditioner!
By AfterYou in forum Firebird / WS6Replies: 4Last Post: 08-22-2010, 07:48 AM -
Top Conditioner
By Vert0787 in forum ConvertibleReplies: 3Last Post: 02-13-2010, 06:14 AM
