Thread: Air conditioner
11-28-2010, 07:35 PM #1
- Aug 2009
- Granbury, Texas
01' Firebird Pewter- 98' Trans Am Black
Air conditioner
When i turn on the car, with the knob for the air on "off" then turn it to a/c, or max. It makes a weird sound like its depressurizing, then when i turn it back "off" it also makes a weird sound, and makes my car make a really loud sqeak sound, Any ideas? or is it just normal
11-28-2010, 07:52 PM #2
11-29-2010, 11:52 AM #3
loud squeal could be bearings going on the compressor or belt. The decompression sound is normal. I know the HVAC lines come off the back of the intake manifold and that is how they get the pressure to activate the ac/heater. When you turn off that pressure needs to go some where. So it has a bleeder value that releases the pressure.
11-29-2010, 11:59 AM #4
This..
Also the line comes off of the MAP sensor and heads towards the tranny on the passenger side fire wall.. Very hard to see but there's a "T" fitting back there also one line goes to the tranny and the other goes to the dashboard controls. I remeber you said something about jacking the car up for the back plug on that side.. I'd check to see if the "t" is still intact and did not crack or breaking.. But I'll tell you also it will be a chore just to see it back there.. But yes the hissing sound or depressurizing sound from behind the control panel is normal for us..
11-29-2010, 03:30 PM #5
- Aug 2009
- Granbury, Texas
Alright, So for the most part this is normal?
11-29-2010, 03:36 PM #6
I'm gonna go out on a limb here and say yes.. The vaccume actuator (better know as a vacume bowl) will sometimes howl or make a sqweaking sound as it releases or compresses.. Does'nt always mean it's bad just annoying.. I would still check for VAC leaks as this can cause a slow movement on the part I mentioned and VAC leaks in general are a bad thing..
11-29-2010, 04:24 PM #7
a/c compressor does NOT sound very good...may just be the video
11-29-2010, 04:29 PM #8
Mine has made that exact noise for ~5 years now since the day I got it with ~26k on the clock.. Still thows snowflakes lol.. But I agree it sounds bad..
You can fix it or live with it imho..
11-29-2010, 07:48 PM #9
- Aug 2009
- Granbury, Texas
Alright! Thanks!
Help: 1999 WS6 Air Conditioner
By madcow in forum General HelpReplies: 16Last Post: 08-21-2012, 02:29 PM -
Air Conditioner
By x-lr8 in forum General HelpReplies: 1Last Post: 08-22-2010, 02:05 PM -
Air conditioner!
By AfterYou in forum Firebird / WS6Replies: 4Last Post: 08-22-2010, 07:48 AM -
Top Conditioner
By Vert0787 in forum ConvertibleReplies: 3Last Post: 02-13-2010, 06:14 AM -
Air Conditioner Conversion
By JWCHANDLER in forum General HelpReplies: 3Last Post: 05-23-2007, 09:35 AM
