    ls1ftw tigersport14's Avatar
    Tulsa
    98 trans am
    Main crankshaft bearing clearance-oil pressure
    anyone know the crankshaft bearing clearance for the LS1..? Whats normal oil pressure...?
    thanks...
    Tulsa
    98 trans am
    bumppp
    georgia
    1998 pontiac trans am
    thanks...
    a haynes book can tell you. im at work or i would look in my book for ya, cause i cant remember. oil clearance for the bearings has something to do with i believe some kind of mylar strip(?) laid long ways on the crank journal and put main caps on,torque, and remove to measure how wide the strip was flattened out and the book gives you allowable tolerences
    Tulsa
    98 trans am
    oh alright...thanks
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    factory specs
    connecting rod bearing clearance 0.015 - 0.063mm or 0.0006 - 0.00248 in.
    main bearing clearance 0.018 - 0.054mm or 0.00433 - 0.02 in.
    Tulsa
    98 trans am
    thank you
    orlando, fl
    2014 camaro 2ss/rs
    no problem.
  1. Veifying Main Bearing Clearance - Checked Mains - CHP Step B
    Last Post: 11-10-2010, 03:20 AM
  2. Main bearing Side bolts
    By cfgioja in forum Internal Engine
    Last Post: 09-05-2010, 07:09 AM
  3. Main bearing question?
    By 1999sscamaro in forum Internal Engine
    Last Post: 08-06-2010, 01:20 PM
  4. Help: main bearing clearance ls1
    By crossbredfoxbody in forum Internal Engine
    Last Post: 04-04-2010, 05:30 PM
  5. Main Bearing Clearance - Cranky Dispositon
    Last Post: 09-29-2007, 06:50 AM
