Thread: Main bearing Side bolts
09-03-2010, 09:31 PM #1Junior Member
- Aug 2010
- Clarksville, Ar
various- 1986 Turbo 944
Got my rotating assembly back today and am starting to check bearing clearances and reassemble the block.
My question is based on what the book says.
Chilton says to use new main bearing cap side bolts, due to o rings will be damaged on the old ones. The problem I am running into is that the old ones don't have o rings.
So on third gen aluminum blocks do I need to replace these side bolts?
09-04-2010, 03:06 AM #2
I reused my side bolts, with no problems !
09-05-2010, 04:35 AM #3
09-05-2010, 07:09 AM #4Junior Member
- Aug 2010
- Clarksville, Ar
thanks guys
Main bearing question?
By 1999sscamaro in forum Internal EngineReplies: 1Last Post: 08-06-2010, 01:20 PM -
Help: main bearing clearance ls1
By crossbredfoxbody in forum Internal EngineReplies: 4Last Post: 04-04-2010, 05:30 PM -
Rod,main and head bolts
By JMac in forum Internal EngineReplies: 8Last Post: 06-14-2008, 09:44 AM -
How hard is it to spin a main bearing?
By Daniel P. in forum Internal EngineReplies: 26Last Post: 12-05-2006, 11:31 AM -
ARP Main Studs and Rod bolts
By greatwhitess in forum Parts For Sale / TradeReplies: 0Last Post: 08-07-2006, 06:51 PM
