Results 1 to 19 of 19
Thread: LCA Questions
05-20-2007, 08:41 PM #1
LCA Questions
I was looking at Rear Lower Control Arms and had some questions. Any or all answers are greatly appreciated:
- Spohn, UMI, BMR, J&M, or any other companies? Why?
- Boxed or Tubular? Why?
- Steel, Aluminum, or Chrome Moly? Does it really matter? Why?
- Adjustable or non-adjustable? My car's not lowered. Does it matter? Why?
- UMI Performance Non Adj. Panhard Rod & LCA's for $164.95 Good idea? Why?
Once again, any knowledge and input are greatly appreciated. Thanks.
05-21-2007, 09:45 AM #2
go adjustable and i wouldn't go chrome moly unless ur gonna build the car for 600 + hp
05-21-2007, 01:54 PM #3
05-21-2007, 02:20 PM #4
- Feb 2006
- Galveston, TX
NBM- '98 Ram Air Formula
All good questions and I am very interested in hearing some good, knowledgeable responses. I have been hesitant because I too want to do it right the first time. Right now I would go BMR tubular non-adjustable with the combination poly/rubber mounts.
05-21-2007, 06:03 PM #5
when it comes to the trailing arms, all the companies are comparable.
boxed, because it's harder to bend a square tube versus a round tube.
don't know of any aluminum ones. chrome-moly is lighter and stronger than a steel version of same diameter/thickness.
you don't have to have adjustable. just makes it so you can center everything up perfectly. even though your car isn't lowered, the rear isn't perfectly centered. my 86TA had a thrust angle of .29*. this means the rear was pointed to the right of the centerline of the car. this makes the car look like it's going sideways down the road. called dog walking. and it was to the right of center as well. so, adjustable panhard rod fixes the side to side difference. adjustable trailing arms fixes the front to rear differences.Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
05-21-2007, 06:34 PM #6
- Feb 2006
- Galveston, TX
How do you go about even beginning to straighten up a situation like that. Does it take a professional? I assume it is not a job for an amatuer.
05-21-2007, 06:37 PM #7
take it to an alignment shop. they will correct the thrust angle (trailing arms) for you. the side to side difference (panhard) is just a visual thing.
05-21-2007, 06:55 PM #8
- Feb 2006
- Galveston, TX
But that is only if you have the adjustable parts? Or can it be done with say stock pieces.
05-21-2007, 06:56 PM #9
cannot be done with stock pieces, as they are not adjustable.
05-22-2007, 09:09 AM #10
- Feb 2006
- Galveston, TX
Thanks! I assumed not with the stock pieces. I meant to ask about the non-adjustable aftermarket pieces.
05-22-2007, 03:24 PM #11
same thing, they are not adjustable. so, just bolt on and go.
05-23-2007, 12:24 PM #12
- Pittsburgh, PA
any of them-best price FTW. If you order a lot from one company, expect good deals.
has been mentioned, boxed is stiffer
Weight and strength. Chrome Moly is the best of both in that case but most expensive. Steel is heavier and the least expensive. Aluminum is weight savings, dunno how durable it is?
I think if you're going to put new ones on, you may aswell do adjustable. HOWEVER...i think only tubular arms are adjustable
Once again-adjustability is personal preference, you never know if you'll ever lower the car.
05-23-2007, 12:49 PM #13
- Mar 2006
- who knows
are you an auto-x/road racer or a drag guy
05-23-2007, 01:34 PM #14
05-23-2007, 03:08 PM #15
- Mar 2006
- who knows
id go for the umi deal for reduced wheel hop
06-12-2007, 04:05 AM #16
- Jun 2007
- fresno, ca
if you want a serious control arm you need to get one with a pivoting type bushing on the frame side. an dyou wont find one at your price range, tubular is the strongest in that application by weight. thinner walled tubing is stronger than comparable box tubing. in other words you can make a box lca stronger than a tubular one, but at the expense of weight (unsprung weight at that) and chromolly is stronger by weight than steel, but the whole point of using chromolly is that you can use a thinner (lighter) piece and have the same strength as a thicker steel piece. so in teh end they are the same strength cause the chromolly piece will be much thinner and lighter (but still giving the same strength as the thicker steel) chromolly is a luxury item and square tubing is heavy. go with tubular and non adjustabe for ultimate strength to weight ratio, and if you get urethane bushed on both ends it will bind and make noise, but that is the price we pay for a good deal! i use currie johnny joints in my lca's and i have never had any problems or negative feedback, plus they are greaseable! (weather proof)
hope this helped and good luck!
06-12-2007, 04:11 AM #17
- Jun 2007
- fresno, ca
also stay away from rod ends on anything for a street car they are not weather proof, greaseable, or shock resistant and one nice hit they will explode. try to only use greaseable joints if possible and most companies use cheap rod ends anyway cause they "look" cool. but they do not function for street cars unless you constantly check and replace them.
06-12-2007, 11:28 AM #18
- Jun 2002
- Montreal, CANADA
You just joined and you seem to have a vendetta for rod-ends.
Not only is the information false, your claims are unfound.
did you have bad experience w/ rod-ends ?
You can get rubber covers, but if you clean them once in a blue moon and grease them, they last a very long time.
Also having good rod-ends, will not create noise, and way better handling characteristics.
Actually, poly is worse than stock rubber when it comes to cornering due to the binding... poly is really meant for straight-line ONLY.Eugenio_SS
06-12-2007, 10:47 PM #19
- Jun 2007
- fresno, ca
you are absolutely right about the poly being for straight line only, if used at both ends of the control arm it will bind. im only saying that rod ends will wear out and eventually fail on a "street vehicle" that is driven daily. they have their place due to light weight and easily replaced, but they are a solid link in a suspension with no give, and are generaly not greaseable or rebuildable.
i personaly replaced all my rod ends on my jeep suspension with johnny joints after my steering linkages failed twice. they just have no tollerance for shock and will eventually fail, especially when subjected to weather. just my experience.
i dont really have any vendetta, just trying to help out someone with what i have seen and experianced thats all. and new to this site does not mean new to suspension or rod ends so please dont toss me into "that" category. thanks!!!
A few questions
By blackcar in forum External EngineReplies: 5Last Post: 01-30-2012, 11:35 AM -
Upgrading intake on a stock LS1, questions, questions.......
By mrbvlo in forum External EngineReplies: 6Last Post: 12-30-2011, 11:40 AM -
z28 questions
By stickinpcb in forum Internal EngineReplies: 2Last Post: 04-25-2007, 01:37 PM -
Questions
By The Silver Goat in forum GTOReplies: 2Last Post: 04-22-2007, 07:26 PM -
Questions
By Airguy in forum Firebird / WS6Replies: 3Last Post: 04-21-2007, 12:11 PM
