Results 1 to 3 of 3
Thread: Questions
04-21-2007, 01:46 AM #1
Questions
Modifications to date:
1) K & N CAI
2) 160 thermostat
3) diablo tune (reset both fans)
4) increased WOT by 5% on each bank to avoid leaning out - i got two codes (lean fuel on both banks) which i quickly fixed
5) Increased rev limiter by 100rpm through the entire gear box (M6)
Questions:
1) Should I get an electric water pump? I think'in yes...given the new tune seems run to be running hotter and electric pumps push a higher volume of water
2) How much HP and torque do you think I gained at the fly wheel?
I'm going to a dyno this summer and I'm not sure what to expect, but she feels significantly quicker.
Also, I thinking about new exhaust headers (ceramic coated) to contain the heat. My goal is to look stock though so I not changing from the cats back. So if I go 1 7/8 to a stock cat back am I defeating the purpose?
Input would be greatly appreciated.Last edited by The Silver Goat; 04-21-2007 at 04:06 AM.
04-21-2007, 06:24 PM #2doesn'tplaywellwithothers
- Jan 2007
- Mayberry....(Indiana)
Black- 2004 GTO
Here is what I had on my 1st base dyno SLP ceramic coated headers, SLP MAF sensor, LoudMouth2 exaust, K&N CAI, and Diablo tune...332.4rwhp is what I got. You'll be around 300-315 rwhp with no headers and exaust, thats what I would guess, If you get headers I would go with Stainless Works, because they do not drop down as low as my SLP ceramics, all though they look great and work well, but I wished I'd done some more reasearch..btw I'd do whole exaust, if I were to put on headers.
'04 gto M6 slp ceramic coated headers,B&m sport shifter,harrop cover,3.5"aluminum BMR driveshaft, BMR axle stubs, BMR Half shafts, BMR SFC's, loudmouth2 exaust,90mm FAST T/B,Magancharger(high helix upgrade)......other misc. suspension,Cross drilled, slotted rotors. Meth Kit, spraying @ 3psi and up
04-22-2007, 07:26 PM #3
Personally, I would not have used the 160* stat. These engines are designed to run within a certain heat range. IMO, I would install the pre programmed performance tune with the predator (with exception to the fan delays) and leave it till you get some headers and get it on the dyno for a full tune.
Stick with 1 3/4" headers......there is absolutely no need for 1 7/8" on these cars. Stainless Works and Kooks are about the best headers on the market....coating is up to you, but there is really no need. And lastly, no, there is no need for an elec. water pump.
Save your cash for the headers and tune.'06 M6 GTO (Redrum)
Comp 228/232
SW LT's
GMM Ripper
JHP Pod
C.A.I. Air Box
HPS Tuned
421rwhp/401rwtq
A few questions
By blackcar in forum External EngineReplies: 5Last Post: 01-30-2012, 11:35 AM -
Upgrading intake on a stock LS1, questions, questions.......
By mrbvlo in forum External EngineReplies: 6Last Post: 12-30-2011, 11:40 AM -
z28 questions
By stickinpcb in forum Internal EngineReplies: 2Last Post: 04-25-2007, 01:37 PM -
z28 questions
By stickinpcb in forum Camaro / SSReplies: 1Last Post: 04-22-2007, 02:49 PM -
Questions
By Airguy in forum Firebird / WS6Replies: 3Last Post: 04-21-2007, 12:11 PM
