Results 1 to 14 of 14
05-15-2007, 07:59 AM #1
- mo
hugger orange- 1999
backspacing for MT ET drag wheels skinnies
Just wondering if anyone knows the backspacing to run with the MT ET drag wheels on the front skinnies? they are available in 1-3/4 and 2-1/4 backspacing, so just wondering which is the better way to go?
05-26-2007, 08:25 AM #2
- Oct 2005
- Michigan
Black- 1995 Z
2.25
05-26-2007, 10:50 AM #3
- Thornton, CO
My ProStars are 1.75" BS.
Then spaced out 5/8" to clear the calipers without rubbing.
05-28-2007, 01:59 PM #4Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
05-28-2007, 05:51 PM #5
I used the convo-pro's 2.25 and my 7" grinder !!!
05-28-2007, 06:09 PM #6
05-28-2007, 06:11 PM #7
5/8" on stock wheels studs won't even bolt up.
05-28-2007, 06:15 PM #8
- Mar 2006
- Northeast Louisiana
Hugger Orange- 98 Camaro
My convo pros didn't require any grinding, front or rear
1998 Z28, Hugger Orange, SLP MAFS, SPL Headers, off-road Y, Hypertech, Ram-air, 3000 TCI Stall, 3:73 gears, a4, S&W chassis package, Wolfe Racecraft 6-pt bar, HSW 125 dry kit, SLP Line-locks, Kirkey Prostreet seats, RCI belts, Convo-Pro's w/ Hoosier QTime DOT's
05-28-2007, 06:25 PM #9
05-28-2007, 06:36 PM #10
05-28-2007, 06:38 PM #11
05-28-2007, 06:42 PM #12
- Thornton, CO
I would have failed tech that way. Guy checked the wheel studs.
Even though the shank lugs will fit, I like having the longer, stronger studs in there. Reassurance I guess.
05-28-2007, 06:56 PM #13
no problem being safe. yeah, if we ever had real tech, i wouldn't pass either. the rules say the stud has to be at least even with the top of the lugnut.
05-31-2007, 07:01 PM #14
I have 1.75 bs on my draglites and I had to do a ton of grinding.
Set of Drag Skinnies and Rear Tires
By ls1camino in forum Parts For Sale / TradeReplies: 2Last Post: 04-12-2018, 05:45 AM -
For Sale: Weld Wheels, Slicks and Skinnies FS
By 02 WS6 TA in forum Parts For Sale / TradeReplies: 17Last Post: 01-03-2010, 05:10 PM -
anybody got drag rims and skinnies on a bird?
By 5second in forum Firebird / WS6Replies: 24Last Post: 10-07-2008, 01:32 PM -
JEGS drag wheel backspacing for Z28
By PEWTER Z in forum Wheels and TiresReplies: 5Last Post: 02-22-2007, 11:43 AM -
backspacing on weld wheels for 99ss
By axlfly1 in forum Wheels and TiresReplies: 0Last Post: 08-25-2005, 02:38 PM
