    IMPORT KILLER PEWTER Z's Avatar
    Pasadena, MD
    PEWTER
    1999 Z28 CAMARO
    JEGS drag wheel backspacing for Z28
    I've been thinking about getting some JEGS draglite wheels, and don't know what backspacing is required for my 99 Z28. The wheels I'm looking at are the 15X4, and the 15X8 wheel Prostar looking ones. Will I need a spacer for these wheels too, and brake caliper grinding too? Thanks.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    15 x 8 will need 5.5" backspacing. are these draglites actually Weld Racing that you are buying through Jegs? if so, then yes, spacers and/or grinding down of the calipers is required. i just ground my calipers until they cleared without spacers.
    scroll to the bottom for pics
    http://www.stealthram.com/wheels.htm
    I think they are mrr23.
    If I recall correctly, Jegs/Summit picked up the ProStar design when Weld went out of business.
    15x8 needs a 5.5" BS.
    15x10 needs a 7.5" BS.
    Grinding the rear caliper is required for both wheels to fit. More needs to be removed for the 15x10.
    Lot more than I thought.
    orlando, fl
    2014 camaro 2ss/rs
    the look of a 10" wide wheel is worth it though.
    and weld is not out of business. i talked with them at PRI when i passed by their booth. they were bought by the same company that owns american racing. name begins with a Z. the rep said, by january, they should be up to about 30 day backorder times.
    Well that makes sense.
    Weld got bought out. AR has them, so maybe they will go down a little.
    Got mine last summer when the rumors were flying.
    northeast
    black & silver
    1999 Z28
    the only problem wit the jegs/summit wheels is the biggest backspace they offer is a 4.5???
  1. Drag Wheel & Tire Setup
    By ls1camino in forum Parts For Sale / Trade
    Last Post: 06-08-2013, 04:14 PM
  2. Wheel Offset and Backspacing
    By herculesrider1 in forum Wheels and Tires
    Last Post: 12-11-2009, 09:52 AM
  3. wheel backspacing
    By screaminbird in forum Wheels and Tires
    Last Post: 10-09-2008, 11:33 AM
  4. backspacing for MT ET drag wheels skinnies
    By huggerz28 in forum Wheels and Tires
    Last Post: 05-31-2007, 07:01 PM
  5. Wheel backspacing, what to look for, what to avoid?
    By Zapper2003 in forum Wheels and Tires
    Last Post: 04-25-2007, 05:14 AM
