Results 1 to 20 of 39
Thread: Yuck!!!
    TIMMMMMAY TX_WS6_02's Avatar
    Ingleside, TX
    2002 Trans Am WS6
    Yuck!!!
    I was inspecting my car today to make sure everything is good for my trip to Virginia tomorrow. Lookie what I found...
    It's from the side resivoir by the battery, not the main opening to refill the radiator. Anyone ever see gunk like this???
    Ontario, Canada
    yellow
    02 Collector Trans Am
    If have an A4, it looks like your rad let go and tranny fluid mixed with the antifreeze. Check your tranny fluid and see if its all pink and thick like that. If so, you have bad news and youll new a tranny rebuilt. I would recommend getting a tranny cooler so that doesnt happen again.
    Ingleside, TX
    2002 Trans Am WS6
    Quote Originally Posted by 02cetransam View Post
    It's an M6...The car doesn't run hot and she runs great. It's dark right now so I will have to wait til tomorrow to check it out. I really hope nothing is too screwed up...I really need my car to be operational...have to make a 1600 mille trip tomorrow.
    Ingleside, TX
    2002 Trans Am WS6
    I dipped the stick back in there over and over again and it came out looking like that everytime...you don't think it could be some jacked up additive that the previous owner put in there?
    408 ci + 4000 stall = fun lancesT/A's Avatar
    Abilene Texas
    2002 SS
    Quote Originally Posted by TX_WS6_02 View Post
    it could be some additive but you should atleast try flushing your radiator just to be safe especially if you are going to make a long trip, but it is your car.
    San Diego
    2002 T/A
    Don't forget about the power steering cooler, if you have one. If it pops the same thing will happen. Check your power steering fluid.
    Member Tony180a's Avatar
    Clarksville, Tn
    1999 Trans Am WS6
    I had the exact same thing. Has your low coolant warning light come on ? Mine was a ruptured coolant line in the radiator hose. Long story but it still pisses me off because Pontiac would not cover it even though this surfaced with less than 7k on th odometer just not properly diagnosed by Pontiac technicians (until it was out of warranty) This wil cause failue of your rack and pinion.
    Ingleside, TX
    2002 Trans Am WS6
    Quote Originally Posted by Tony180a View Post
    Dammit!!! No my light hasn't come on. With that rack and pinion failure...will that cause your engine to start knocking a lil bit?
    shouldn't...being that rack n pinion are steering elements
    Marylandistan
    2001 Trans Am (sold)
    Coolant's supposed to be changed once in a while.
    w
    w
    w
    Yeah, what's your mileage? Just have it flushed and go from there.If you do a search for dextron coolant on the internet, you'll find plenty of other people who have had the same thing happen.
    Marylandistan
    Dexcool.
    w
    w
    w
    That's right, dextron is brake fluid, isn't it? Or ATF fluid. Whatever, at any rate, if you do a search for the factory coolant, you'll come up with similar stories.
    Member intheclouds1977's Avatar
    QC Illinois
    2000 WS6 M6
    Looks like either insanely old Dexcool or somebody mixed mixed the green stuff with Dexcool. Mixing the two makes a thicker mess that's corrosive. Kiss your intake gasket goodbye if that's the case and pray it hasn't damaged the passages in the block/radiator.
    QC Illinois
    2000 WS6 M6
    Quote Originally Posted by acrylicophobia View Post
    No offense, but that site is worthless. It's a bunch of non-mechanical idiots that blame their problems on DexCool. DexCool is superior to regular coolant as long as it is used properly. It must be changed regularly (not the 100k miles GM recommends) and must NEVER NEVER NEVER be mixed with the green stuff. I read several posts on the above site and every one sounded like an idiot who knows nothing about cars who probably didn't properly maintain their Dexcool.
    I run Dexcool in all 3 of my GM vehicles. 143k miles, 105k miles, and 62k miles without a single problem because I properly maintain the cooling system.
    The starter of this thread obviously has not properly maintained his system. That's isn't DexCool's fault.
    Now granted, the green stuff isn't corrosive if not properly maintained...so it's better for the mechanical moron who doesn't take proper care of his/her vehicle. However, if you properly maintain the cooling system, DexCool is far superior for cooling. It should not be blamed for damage when the owner simply didn't follow proper maintenance schedules.
    w
    w
    w
    True, but I was only trying to show that other people have had the problem. And from what I've read, you're right, it's caused by improper maintenance, in particular, letting the coolant level get too low.
    At any rate, the solution is to flush the coolant, and keep it at the proper level.
    Last edited by acrylicophobia; 05-15-2007 at 07:41 AM. Reason: Trying to not sound like I'm trying to pick a fight.
    San Diego
    2002 T/A
    I flush the green stuff out of all of my non-GM cars and fill them with Dex-Cool. Great stuff, if properly maintained.
    w
    w
    w
    I don't know if I'd go that far, but if it came with it, I'd stick with it.
    My '04 Dodge pickup came with HOAT coolant (available as Zerex G-05), and I wouldn't replace it with Dexcool, but I wouldn't put in plain green coolant either. From what I've read, other than coolant life, the main reason for using different coolants is corrosion protection.
    Ingleside, TX
    2002 Trans Am WS6
    Quote Originally Posted by intheclouds1977 View Post
    The starter of this thread has maintaned the car. i have had it for 5 months. Bought the car with 35,000 miles on it. Now have 46,000 miles on it. Car runs like a bat out of hell. Just has a slight knock when it is not all the way warmed up. Never runs over 210 degrees. Power steering fluid is perfect.
    Everyone thank you for your input. I am about to get out of work and start troubleshooting...I will let everyone know the verdict...
  1. Interior color Yuck!!
    By Boothe in forum Appearance Section
    Last Post: 06-18-2012, 09:04 AM
  2. yuck...soap scum
    By terrytheexpert in forum Showcar and Detailing
    Last Post: 09-22-2008, 11:51 PM
  3. Career change, yuck
    By 98-LS1 in forum Almost Anything Goes
    Last Post: 09-07-2006, 11:12 AM
