Thread: hydraulic problem?
05-11-2007, 10:17 PM #1SlamminGears
- Apr 2007
- Tennessee
Black- 01 TransAm WS6
hydraulic problem?
I have an annoying problem.
If I get into the rpms my clutch pedal goes to crap. You have to pump it up to get it to work. I dont have to be shifting for the problem to develop although it is worse when shifting hard. It does it in all gears but for example if I am in third just putin along and decide to wind it out and bring it back down (all in third gear) when I go to forth at a normal rpm the pedal goes half way to the floor before the clutch ingages. I have to pump it up. If I drive normal it works fine. I have a new slave, Mcleod line, and master cylinder. Its been bled. The master cylinder is an autoparts special. Does this make a difference? I am also wondering if it could be a pressure plate problem? Any ideas would be greatly appreciated. I am tired of losing races from this. Thanks for ya'lls time.
05-11-2007, 10:51 PM #2
05-12-2007, 07:20 AM #3SlamminGears
- Apr 2007
- Tennessee
thanks for the reply. The fluid level stays fine. I am running out of ideas.
05-12-2007, 12:07 PM #4
You state it has been bled. how long did you spend on bleeding it. sounds like u might have air in the lines still.
05-14-2007, 09:48 PM #5SlamminGears
- Apr 2007
- Tennessee
I tried several times. Finally took it to the dealer, they pressure bled it to flush it and force new fluid in. I still had the problem leaving there so when I got home I popped off the master cylinder and gravity bled the thing and still no luck. There was no play in the master cylinder what so ever when I got done gravity bleeding it and put it back on the car. I am maybe leaning toward a bad pressure plate. I don't know. Its a Spec III
05-14-2007, 09:51 PM #6
06-26-2007, 10:57 PM #7SlamminGears
- Apr 2007
- Tennessee
I finally put a new clutch in.(Ram Powergrip feels great) I couldn't see any physical damage to the pressure plate, but I did notice the plastic housing the throwout bearing rides in was eat up on the inside. Almost like the plastic housing was spinning with the bearing at times. I think the housing was hanging on the slave shaft until I pumped the pedal to get it back to the pressure plate. Not sure but it is the only thing I could physically see. Either way I have a good clutch pedal again WOOHOO! Thanks for all the replies yall.
need help with hydraulic line
By turyg ls1 in forum Manual TransmissionReplies: 4Last Post: 10-25-2010, 07:12 PM -
Need new clutch or is this a hydraulic's problem?
By chris5 in forum Manual TransmissionReplies: 4Last Post: 05-27-2009, 08:12 AM -
Hydraulic Fluid on E
By FantaZGuy28 in forum DrivetrainReplies: 0Last Post: 09-11-2007, 04:08 PM -
?hydraulic lines?
By rwta in forum Manual TransmissionReplies: 2Last Post: 09-11-2007, 01:00 PM -
possible clutch hydraulic problem?
By chris5 in forum Manual TransmissionReplies: 4Last Post: 06-26-2007, 03:41 PM
