Thread: need help with hydraulic line
10-25-2010, 04:12 PM #1
Im trying to disconnect the hydraulic line that connects to the slave cylinder
but it wont come off.. I know u have to push in the plastic ring , it also has a metal clip that clips on side ways.. my ? is does that clip have to come off completly and if so theres not enough room to remove it all the way...
can anybody help me solve this problem
10-25-2010, 05:38 PM #2
you can use two flat bladed screw drivers to push that plastic ring in. That will be what it takes to get it off. Pull on the hose at the same time. Be careful you don't break the plastic ring. I bought the fuel line disconnect tools to use the second time around. It was still hard, but it was a little easier with the tool. I can't remember the size. I bought three of them. The plastic set of these tools didn't do the trick. I bought the aluminum ones from checkers.
10-25-2010, 06:14 PM #3
Well I just changed the slave myself and I still have the tool that came with it but like said there's a metal clip right behind the plastic ring its on the slave part.. U know what I'm talkin about ?
10-25-2010, 06:51 PM #4Senior Member
- Apr 2008
- Madison, WI
The white plasic collar needs to be pushed inside the slave fitting. It somewhat easy to push the while collar flush with the slave fitting, but a little trickier pushing it inside a little bit.
I don't remember a metal clip being in the way...but its been a while.
10-25-2010, 07:12 PM #5Member
- Sep 2010
- WI
- 2000 Trans Am
Hydraulic Clutch Line Remover Tool
By SuperSport346 in forum ToolsReplies: 6Last Post: 02-11-2010, 04:41 PM -
how do i get clutch hydraulic line back in??
By jmatt07 in forum General HelpReplies: 8Last Post: 10-21-2009, 05:49 AM -
Wanted: Hydraulic master cylinder clutch line
By Chronic442 in forum Parts Wanted / TradeReplies: 0Last Post: 05-12-2008, 02:56 PM -
NTB: Hydraulic Clutch Line 98-02 TA
By rbrack in forum Parts Wanted / TradeReplies: 2Last Post: 12-11-2007, 06:28 PM -
Braided Hydraulic line
By FunkyTownFBody in forum Manual TransmissionReplies: 0Last Post: 11-14-2005, 06:36 PM
